What axle is this? No pic desription
Discussion in 'The Garage' started by gmcjimmy88, Feb 22, 2006.
  1. gmcjimmy88
    gmcjimmy88 1/2 ton status
    Feb 10, 2005
    559
    Fayetteville North Carolina
    I went junkyard searching today and ran across an axle that I am not sure about. It is an eight lug and has the protruding hubs like a 14 bolt (this is what caught my attention). Upon further inspection I noticed it has a round diff cover with ten bolts. It is almost perfectlyround sorta like the 50's baby moon hub caps but bigger. I wish I had my camera with me but I do not. It was under just a frame so I do not know what the truck is/was. Thanks if anyone can tell what it is. I am guessing it might be a 70 or 60 or something to that effect. I looked at the axle identifier on here but did not see it. Will look some more also. Thanks again.
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Most likely an axle that GM used from 1947 to 1972 on various 3/4 & 1-Ton trucks referred to as an Eaton .
    Did it have a removeable pinion support ?
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Id bet a winning lottery ticket its an eaton... search to find mor einfo/ pics about em
  4. gmcjimmy88
    Feb 10, 2005
    559
    If you are referring to four bolts around the driveshaft yoke then yes. If it is an eaton are they worth anything? Strong or not worth using? The place I was at is crushing many cars and this was in the "to be crushed area". I assume that getting gears for it might be more difficult than say..... a 14 bolt or something more common? Thanks for the help. ALSO It had a roughly 1'8 inch strap at the lower side of the diff cover Looked factory but I do not know. Thanks for the assistance.
  5. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    If my memory is working the pinion support should have five or six retaining bolts .
    I am assuming that the four bolts you are speaking of are the bolts holding the straps for the u-joint???
    At this point we will need a picture to give good info - sorry.
    Tom
  6. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Did it look like this [​IMG]
  7. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    Yes, the Eaton axle is worth something and strong. They typically came with 4.57's or 5.13's, so you may not need to buy gears. The best thing is that some had factory Detroit No-Spins. An undesirable but easily fixed feature is the axle splines. They are course (can't remember, but I think 17 spline?) but you can swap in spiders and axle shafts from a 14 BFF. These have a one piece steel housing and drop-out diff similar to a Furd 9 inch, but with a removeable rear cover. Parts can be harder to find, so I like to grab whole axles to keep for parts. Most of the trucks that had these axles also had SM420's which I happen to like too.:waytogo:
  8. gmcjimmy88
    Feb 10, 2005
    559
    Cool thanks for the input to all. I am not really interested in this but if anyone else is let me know. It and a few 14 bolt FF are in a local scrapyard in vehicles about to be crushed. If anyone is in need of one pm me and I can get you the info. I will be getting a 14 bolt I think unless I can get to jersy for the other set I found.
  9. K30CJ
    May 16, 2003
    429
    IN
    Too far from me, but you might consider it over a 14 bolt if clearance is a factor.
  10. 79k20350
    Nov 22, 2004
    7,757
    Ct
    these axles have 2" over a shaved 14 bolt stock and can be shaved for more clearance than an dana 44:eek1: also the housings are not cast so it is convienant cause you can easily weld to it.
  11. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Also, have you ever seen the pinion gear for an Eaton? 2" diameter :eek:
