What backspacing to run with 4in lift and 35's on 15in wheels on 8 lug
Discussion in 'The Garage' started by fourwheelinj1, Dec 19, 2003.
  1. fourwheelinj1
    fourwheelinj1 Registered Member
    Sep 18, 2002
    18
    Wake Forest North Carolina,USA
    What backspacing to run with 4in lift and 35\'s on 15in wheels on 8 lug
    I need to know the best backspacing to run? I am planning on having a 4in lift and 35x12.50 tires on 15x8 wheels. I am running 3/4 ton axles so i need to know the best backspacing to fit the tires with the least amount if trimming and not having to grind calipers excessively. Also where is the bestplace to buy 15x8 8 lug black steel wheels rock in the rockcrawler style.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: What backspacing to run with 4in lift and 35\'s on 15in wheels on 8 lug
    summit
    3.5" BS (little grinding)
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    4wpw has some with 2.75" bs. Most tire/wheel stores can custom order any steel wheel with as little as 2.5" bs, there is a build charge of around $10.
  4. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    How far out will the tires stick out with this sort of back spacing? The 16" setup costs quit a bit more $$$ than the 15's so it is definitely something to consider...
  5. Grim-Reaper
    7,385
    Atlanta
    I'm running 4 inches but that's on 10bolt. 4 inches puts the tread inline with the fender on the front. I'm on 15x10 rims. I moved the axle foward 1 inch. I'm trimmed back far less then most. My inner fenders are uncut and in stock location. I'm cut right up to them.
    On a 15x8 I'd look at splitting the difference and run about 3 inches if it's available. It it's not you should be able to get a 3.5. I wouldn't go 2 unless you want to really hack the fenders for clearence.
    That should not put your tire out any farther then I have it and minimize the grinding you need to do on the caliper. To far out and it makes more problems for clearence on the back side of the fender opening. You could go more up to 4 inches but your into the Tierod ends with any more. The weights on the wheels wore a groove into the boot on my Tie rod ends.
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I've got a secret for you and everyone else. 15x8's...GET 2 3/4" BACKSPACING!!!!
    I am currently running this setup (by accident, 4WPW screwed up because I actually ordered 4.25" backspacing). I've never been happier with a screw up.
    1) I had to do NO grinding on the calipers/backing plates.
    2) The rear tires line up almost perfectly with the fenders...giving the look that guys are going for when buying and installing wheel spacers in back.
    3) The front tires only stick out from the fenders maybe an inch or two. I did the math (based on wheel mount surface, backspacing, rim size, etc), and my old 6 lug setup with 15x10" and 4" BS figures out to be the same outer-edge-of-rim-to-outer-edge-of-rim distance as my setup now with an 8 lug D44, 15x8" and 2.75" BS. If you were to get 15x10's instead of 15x8's, then yeah, the tires would stick out more both front and back.
    There are a few pics of my setup in my webshots album. Have a look, I think they're in the "3/4 ton axle swap" albums.
    I should have more pics of my truck up in a week or two after my winter wheelin' trip.
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    rear spacers arent there for looks, they are there to bring the rear tires to the same track width as the front. Any asthetic benefits are superficial and not especially relevant.
    j
  8. heavy4x4
    Aug 28, 2002
    3,270
    While that may be true, I'd be willing to bet that at least half of the people who buy those spacers are going for the "looks" part of it. /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  9. fourwheelinj1
    Sep 18, 2002
    18
    So if i am going to run 15x8 with 35's on 4 in lift with 3.5 of backspacing, How much fender trimming will i have to do?
  10. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    im running 35's on 4" lift with no trimming.
    nick
  11. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Depends on what you want to do w/ it and weather or not you unhook the sway bar and if you move the axle forward and how tall your 35 realy are and how high you lift accually is and...
  12. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    true, plenty o pillowbiters into bling. /forums/images/graemlins/rotfl.gif
    j
