what backspacing with my 14bff?
Discussion in 'The Garage' started by shaun89, May 23, 2006.
  1. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    i have a 14 bolt im putting in my truck and i need to get rims to go with it....i asked my friends and they are all saying different answers for backspacing...i did some research and found that 4" would be a good choice, does anyone have some advise before i go and spend money on rims? should i measure my axle before i get rims?:confused: sorry for the pain the ass story
  2. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    4" should work just fine with a 16" or bigger diameter wheel.
  3. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    what rims size for tires are you going to run? and are you going to do a 60 front soon?
    if 15" and 60 front soon then run 2.75 backspace rims as it will clear the calipers with no problems and no grinding. if not then just the 4.25 backspace that all run.
  4. stockk5
    Apr 13, 2004
    2,035
    71
    Cromwell, CT
    im going to be running 15x10 rims on the 14 bolt, i also have the smaller of the 14 bolt drums on there. its not the big "semi truck" drums. so 4" should be good?...to make them level with a d44 front?
  5. shaun89
    Aug 7, 2005
    1,942
    center of CT..ish
    sorry....i was on my bros name when i asked that...:crazy:
