What brand gears do you run?
Discussion in 'The Garage' started by JUNIOR-K5, Feb 13, 2006.
  1. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    What is a good brand of gears to run need to buy some for my gm d60:confused:
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I could be wrong but I think Yukon are some of the best out there.
    Ira
  3. JUNIOR-K5
    Dec 20, 2005
    387
    SO.CAL
    Cool thanks thats what I was told just wanted to hear another opinion. Yukon it is.
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hmmm....Only really heard bad things about the Yukons. Setup issues, hard to get a good pattern etc. Go do some searching on PIrate, lots to read about there.
    I've got Precision Gear 5.13's in my 60 and 14b. I paid alittle more for them than I would have for a set of Yukons, but didn't have one issue getting them setup or getting a good pattern.
    http://www.precisiongear.com/
  5. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    I'd run factory Dana if you can find some- yukons are real real low on my list of happy stuff- Jess
  6. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Set up a dana 60 Saturday with Yukons. Got a nice pattern and fairly easy to set up. Only had the carrier out about 4 times to get the backlash set correctly.
    All the previous yukons my friend has installed have broken in quietly and we have had no issues on the trail.
  7. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Ive run Yukons, Richmond, and Motive. Randys Ring & Pinion is a good place to get axle stuff and they carry Yukon. Havent had any problems with either. A little whine when coasting from the Motives but thats from the hacks doing the install. Im buying the tools and doing my next gear swap myself. :D
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i run yukon gears in my 60 and 14ff and have never had a problem with them.
  9. drivelineman
    Aug 23, 2000
    707
    what ratio are you going to be running ? I have a set of 4:56 dana gears if you want- Jess
  10. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    dana is good. Superior makes good high end stuff too. For a D60, I wouldn't worry about who makes the gear, so long as its not Genuine Gear. They suck. On an axle like a toy 8" or something, where its not hard to build it up to the point where the r&p is the weak point, I'd go for the high dollar gears.... but in the case of the 60, just get some yukons. They are a good value and should hold up to anything the rest of the axle will. :)
    j
  11. JUNIOR-K5
    Dec 20, 2005
    387
    SO.CAL
    Thanks drivelineman I could use the 4.56 for now that whats in my 14 bolt with detroit. All I would have to do is get a detroit for the front and gears.How much?
  12. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I run Yukon gears and chrome-moly shafts in my Dana 60. No issues yet!!
  13. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Precision.....:bow:
