WHat brand of gears and where to buy??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90blzr, Aug 14, 2001.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Am totally rebuilding a D60 and 14bff. What brands of gears should I look for and which ones should I stay away from?
    Who has the BEST prices on this stuff gears, bearings, etc.....
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Stay away from Genuene Gear(sp?) brand(4WPW brand) I had an opertunity to see a R&P set next to a DanaSpicer set and you can totaly tell the difference in quality and machine work. I have heard good things about Precission (sp?). I bought the DanaSpicer R&P sets when I did my swap.
    Good luck
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  3. k5kraze
    k5kraze Registered Member
    Mar 17, 2000
    27
    AUSTRIA, A-7041 Wulkaprodersdorf
    I always use Richmond Gear, never had any problems.
    Hope that helps.
  4. dyeager535
    26,979
    check out http://www.dorianyeager.com/index2.html
    No anti-theft measures on your truck? No pity when its stolen
  5. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I got Richmond gears from Jegs.
    I get all the excercise I need pushing my luck![​IMG]
  6. Burt4x4
    6,854
    Thease guys seam to know what they are talkin about....
  7. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    I just6 had US Gears put in my rear. Let you know in a year or so if they are any good. lol
  8. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    I've used precision gear and never had any problems and am in the middle of building a new truck and just orded from reider racing, very nice and knowledgable people on the phones. And I ordered it on a friday and they said it would be here tuesday, well a nice surprise it was here on monday. just thought I'd pass that on, not often does a company surprise me in a good way!!!
  9. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I use US Gear and they are great...a friend of mine owns a shop and that is all he will use. Richmond makes great gears, but I don't believe they make them for the 14 bolt ff (or maybe that was because I needed the thick gear for my 4.56 ratio - anyways, they didn't have them)
  10. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    You are right, at least Jegs or Summit doesnt have them.
    Ok, guys, How about:
    14bff-R&amp;P, master install kit (Precision Gear and Timken)
    D60 - R&amp;P, master install kit(Dana/Spicer)
    Both for $529???
  11. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    randys ring and piion, summit racing
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  12. Burt4x4
    6,854
    529 so 265 ea. and were talkin D60 &amp; a14 ya that sound good make sure the master kit has a slinger for that D60, ho wait I'm not sure if a front has one but my rear D60 did and so did my front D44 anyway also ALL the bearings must be MADE in the USA Timkin is said to be best....
  13. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I put Dana/Spicer stuff up front and U.S. Gear in the back. My mechanic said they both "set-up" real nice and he was very happy. He also said Richmond gear is another good one. He said he would refuse to do my truck if I bought Motive Gear...said the stuff was so bad he could barely even install it in another dudes truck.
    '73 K5
    Chevy good...Ford bad
  14. jamiemac
    jamiemac 1/2 ton status
    Mar 26, 2001
    151
    Tennessee
    What ratio are you going with???? Warrantee is the key. Richmond pretty much have no warr...... I believe US Gear,Yukon,and one or two others have lifetime warr. on some of their ring and pinions as long as you buy their install kits. And you will need them if you do any serious offroading. Gears can and every now and then will fail. I can send you pic. of a set of Richmond 5:13's for a ten bolt. They were inspected and said to be set up correctly and failed. Along with a front axel shaft at the same time. They were on a Detroit. So even the best fail!!!!!! So just really look in to your product info before purchase. Thats just my .02 worth though.
  15. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Precison gear and Richmond have been excellent for me thus far. No real problem yet. And I have put some serious BBC power to them on slicks and that is dang near as nasty as anything you'll see out there... at least from your offroading description.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</a>
  16. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Well, you could buy from 4WPW, but ask for the warrenty first, I have..
    Geuss what Its in the mail, say's customer service.
    Good luck
