What can go wrong on an out of round water pump pully?
Discussion in 'The Garage' started by SCOOBYDANNN, Mar 27, 2007.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    My story:
    Had weird knock on the frong of my block--replaced belts, alt, and tightened everything. noticed while tightening alt. the pulley has a crack running 180 degrees around. went to a couple junkyards to no avail. ended up welding the crack up. when the motor is on you can see it wobble still-----
    is this going to hurt anything? im still going to get another pulley but for the short term (to work and back) what is this problem going to cause?
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    have you checked your fan clutch? it might be the cause of the wobble. If its bad enough it can cause the ears of the pump to break. That's what happened on mine
  3. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    might be hard on the bearings. and, at higher rpms, i can imagine the belt hopping around. it depends on how bad it is
