What can I do to get my subs to fit?
Discussion in 'Audio' started by **DONOTDELETE**, Nov 14, 2001.
    I have a 1980 K20 and I am going to put in 2 12" Subs and the only spot for them is behind the seat but I am not exactly sure how to go about doing it. Should I get 2 boxes and put one 12 in each on and put one behind the drive and one behing the passenger with the amp bloted to the back wall between them? Or should I put both 12's in one box then the amp off to the side? What will sound better? Also I was going to get 8 disc changer and bolt it to the floor under the seat on the passenger side, will it fit? Thanks for all your help.
    If it aint Chevy it aint worth anything.
  1. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    There are pics of my stereo setup on the webshots link below. Check it out. Basically have 2 12" subs behind my rear seat, and between my tool boxes. My amp is mounted on the side of the bed, out of the way.
    I'm not a stereo guru by any means, but this set up has worked well for me and sounds tight too. =)
    J
    See the on-going build up of my '85 Jimmy! http://community.webshots.com/user/jekbrown
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My amp is under the driver's seat, and my box is all the way across the cab behind the seat.
    I am loosing that huge box though.
    Tim
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
  4. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    ......the results are SHOCKING! [​IMG]
    -Greg72
