What can I do to make spray paint work better?
Discussion in 'The Garage' started by **DONOTDELETE**, Oct 20, 2002.
    I like most of us spray paint a lot on our trucks. Well a little while back I spent a good amout of time spray painting my tie rod. Like I took it off sanded it down to bare metal (wire wheel) put on three coats of primer, and then three coats of red pait. Well all was well until I presure washed my truck/axles/undercarriage and I noticed that I took off some of the pait on the tie rod. I was a little disturbed, and this is not the first time. What can I do to make this stuff last longer? or make it stronger? Should I put on more coats? less primer? Any help would be great. Thanks /forums/images/graemlins/thumb.gif
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    If you get the piece you are painting to bare metal, then just use Rustoleum to coat the piece, it is made to be sprayed onto bare metal or slightly rusty surfaces. Also, make sure to spray a bunch(3-70 of really thin coats about every 15 minutes in a low humidity environment.
  2. NEOMASTINO2U
    NEOMASTINO2U 1/2 ton status
    Jun 29, 2002
    518
    lynnwood, washington
    also maybe try can of clear coat to keep it protected, did that with my rear end and so far so good even through pressure washing undercarrage. you can get it in spray can to.
    kelly
  3. Ok thanks, so no primer sounds like the trick, because I was using rustoleum on top of the primer. I will aslo try the clear coat. Thanks
  4. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Also make sure to clean any type of oil off prior to applying paint. Paint thinner or brake cleaner work really well to remove the oily residue.
    John
