What can I use as a plastic coating for the tips of my shift forks?
Discussion in 'The Garage' started by Robert79K5, Aug 12, 2006.
  1. Robert79K5
    Robert79K5 1/2 ton status
    Mar 23, 2003
    335
    Douglasville Georgia
    Okay people. While sitting here at work getting work stuff done, and not at the garage getting important Blazer stuff done I started thinking about my shift forks. (I mean who dosnt sit around and think about their shift forks right?)
    Anyways Im going to get around to rebuilding my sm465 soon and I want to do something about the worn out plastic tips on the end of the shift forks.
    It looks like GM probably had a big ole "pot-o-melted-nylon" that they would just dip the ends of the forks in, but Im not sure.
    So I would like to brainstorm here about what might be a good way to get a nice plastic coating back on my forks. Is therre anything I can heat up and melt on there that would work good for this purpose?
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Perhaps flow some brass on there instead? Won't be a noise insulating, but will last longer.
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
  4. Robert79K5
    Mar 23, 2003
    335
    Those are some good Ideas. Brass is nice and soft but I would worry about wearing little pieces of it off that would end up floating around in my gear oil.
    That tool coating... is it the same consistency of the stuff that comes on channel lock handles and such? If so I would almost think that would be too soft and not plasticky (highly technical terminology) enough.
    Thanks for the ideas so far keep em coming!
  5. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    I don't know... not sure something air dry could be tough enough.. I just remember the old tv commercials for the stuff... think it dries pretty shiny and hard as opposed to cushiony like some tool handles..
    I kinda like your original idea of melting something down, but what, I don't know...
  6. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
  7. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
  8. dyeager535
    26,979
    I recall this coming up before, as mentioned, nothing anyone could come up with that is "dippable" was thought to be a good fix.
    Personally, I think the fix is to change the design over to what all of GM's transmissions went to, replaceable "pads" that clip onto the forks. I've got a set of the T56 pads, but it would take some pretty decent machining to make them work, as they are setup for a non-rounded mount, and a thinner fork.
    Never seen the 208/241 fork pads(or coated too?), but if those are replaceable, are they an option?
  9. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
  10. dyeager535
    26,979
    LOL.
    I've got a better idea. Go get a bad computer hard drive, take it apart, pull out the permanent magnets, remove your PTO cover, stick the magnets on the inside, and bolt it back in place. Done!
    Only non-magnetic particles in there will be brass from the synchros, (and the nylon form the forks) which are softer than the steel anyway. Without an actual pump in the transmission, I doubt the brass particles do anything other than settle to the bottom where they sit harmlessly. With the longevity of these transmissions, filtering the fluid would be my last priority in bettering them.
  11. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    How about using a hot glue gun. Those glue sticks dry pretty hard.:dunno:
  12. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Not uncommon to see shifter forks made completely from brass. I know that my old air cooler VW transaxle had one in the 1-2 position.
    Brass also work hardens, which is why it's good for bushings, so the surfaces most likely to try to sluff off will be harder than the rest of it.
    The tool coating bothers me as it really wasn't intended for that use and the end result is very unpredictable.
    How much is a new fork, assuming it's available? Might not be worth doing anything else but buying one.
  13. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    How about rhino lining?
  14. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Same problem, not designed to go there. Is it worth risking the trans by that stuff coming off?
