What can I use to fix a bad hub seal surface on a 14 bolt?
Discussion in 'The Garage' started by afroman006, Jan 17, 2005.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I've replaced the hub seal on my 14 bolt twice and it still spews oil so I think the seal surface is messed up. I've read the article on pirate where billavista used some sleeves to alleviate the problem but I was wondering if there were any other options to consider. Where can I get those sleeves? I need to get this done soon because I'm losing all my royal purple oil and that **** is expensive.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Speedy sleeve at any real parts store.
  3. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    emery cloth fixed mine. smooth it up real nice
  4. ss396
    ss396 Registered Member
    Jan 20, 2004
    29
    Puyallup/Sumner Area WA
    Or you can go to a bearing house for a speedy sleeve, need to measure diameter and width of the sealing surface. They work great.
    If you have a deep groove on the sealing surface, then I don't think emery cloth will work, the sleeve is the repair. If there is no groove or a small one then the emery cloth should do the trick.
  5. 90mule
    90mule Registered Member
    Nov 1, 2004
    10
    make sure the vent is not plugged--- pressure will cause those to fail :frown1: - just my $.02:dunno:
  6. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    CR brand part #99282 :thumb:
  7. afroman006
    Aug 21, 2002
    2,876
    Awsome thanks guys. I will check the vent then if no luck speedy sleeve it is!
  8. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Prepare your wallet for the speedy-sleeve. Especially if you screw it up and end up buying another one.
  9. afroman006
    Aug 21, 2002
    2,876
    ****. I hope they cost $7 or less cause thats all I have right now :(
  10. readymix
    May 30, 2004
    6,706
    26
    $41.99 Ea at Napa
    CR Part # 99282
  11. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    **** you can buy another 14bolt for that :(
  12. readymix
    May 30, 2004
    6,706
    26
    Sure can, But i would use the seal first as i have welded on the spring perches for the correct angle and shaves the Pig. More work than i would want to go through again.
  13. afroman006
    Aug 21, 2002
    2,876
    I have actually thought about getting a new housing b/c the threads on one spindle of the one I have are kinda boogered up. The only problem with that is, it would cost me $300 to get the gears done, plus $40 for spring perches and another $40 or so for u-bolts. Then there is the downtime of the burb, plus I will not be going home to my shop from school for about 4 months so I think I'm **** outta luck as far as a new housing goes for now. I'll speedy sleeve the bitch and see if that does the trick.
