what can i use to seal my trans pan?
Discussion in 'The Garage' started by yunit, Jul 1, 2003.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    What can I use to seal up the trans pan? The stock ones always seem to leak no matter what. /forums/images/graemlins/angryfire.gif
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    For tranny gaskets, (so I don't get RTV in the tranny) I use a high-tack gasket adhesive. The adhesive seals the paper gasket so the fluid doesn't wick out, and keeps the fluid in the pan. /forums/images/graemlins/thumb.gif
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    first do not use a cork gasket always use a felpro gasket second do not over tighten the bolts they only need to be slightly over snug or it will pinch the gasket and it will leak
  4. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    Make sure both surfaces are clean. Then make sure the flange on your tranny pan is flat. Most transmission leaks I have seen were from bad suface prep or warped transmission pan (from overtightening).
  5. gruveb
    gruveb Registered Member
    Jun 26, 2003
    51
    Rio Rico, Arizona
    Torque wrenches are your friends.
    Just like everybody else said, make sure the surface is clean and that the pan isn't dinged or dented. Then if you must use something, only use hi-tak to keep it in place when you start bolting it on.
    Then thread every bolt, then hand tighten every one in a crossing pattern, and then torque them down in a crossing pattern in two steps.
    If they have to be 20# (for example), go 10ft pds on each one, then twenty all in a corssing pattern. Then double check each bolt in (not in a crossing pattern) to see that they are indeed 20ft#'s.
    If everything is clean and level, you should have no leaks.
  6. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    use the high tack, use it on both sides of the gasket.
  7. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    There's a little trick I use for that, as well as valve cover gaskets. Put a very thin coat of RTV over the whole gasket suface, including the edges, hang it to dry (basically turning a cork gasket into a rubber gasket). Once it's dry install in the normal way. HTH....
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I've done the same thing for troublesome pans. Very thin coat, but I don't let it dry, just tack good... No cappilary leaching, and it will stick to the *slightly* deformed rail when the rest compresses slightly.
