What can Phosphoric acid be used for?
Discussion in 'The Lounge' started by 84gmcjimmy, May 1, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    My dad had 3 big jugs of phosporic acid...we only have about 3/4 of 1 left. Maybe around 10 gallons.
    What can this be used for? I know we use it in our pool a bit, and I think my dad used it to help our water from the well, and I think he used it for other things too...but what else?
    It's just sitting doing nothing right now...
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    I used it once to remove mortar off rocks from a rock wall I helped build.
  3. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I have used it for cleaning tarnish off brass and copper. Also works well at cleaning aluminum. Wear gloves and don't splash it on you!!! Also use outside only, the fumes are very nasty. Use baking soda and water to neutralize the acid, when you are done cleaning an object with the acid, and rinse it a bunch.
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Can it be used to clean cement? There is a bunched of stained cement around the pool...
  5. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    they use muriatic acid for pools and cement give it a try :D
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
  7. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    Naval Jelly!
    Its the main ingredient in Naval Jelly,and many "rust reformers" paint stores sell--it turns rust into a black substance that resists rusting again for quite a while....not sure in its pure form how good it works..and it will cause nasty burns,so use gloves and eye protection if you use it on your cement..be careful.. :crazy:
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    That looks like a poem...every second line rhymes with the line before it...
    muriatic acid? Maybe thats what he used for the cement then...I don't know.
    Bob, so I could use it on rust too? mmmmmm :thinking:
