What carb do you run on a 383?
Discussion in 'The Garage' started by pismorat, Jul 6, 2005.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I just bought a 475hp, full roller 383 stroker motor :laugh: It has an Edlebrock 650cfm on it right now and the guy says it is too small. I also have the pumped up Rochester from my 406. Which would be better to start with? Or should I try to get something bigger to begin with? Thanks.
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    If useing off road, the Q-jet is the first choice for a carb.
  3. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    or you could o get a predator! they are the bomb
  4. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Just to throw another one out there, I'm running a Holly ProJection 4D EFI System on my stroker
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    I'll 2nd the EFI option! ;) :thumb:
    I think Summit recommends a 750cfm with their 383...
  6. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    What Carb
    That 650 should be fine unless you plan on running the motor at WOT alot. You'll have more and better low end, and better throttle response. I'd at least drive it first and see. Alot depends on your cam specs too.
  7. icer97
    icer97 1/2 ton status
    Jun 15, 2005
    116
    Missouri
    Better run a 750 or so. Id say a Barry Grant Mighty Demon, or a proform Holley! Or if you got the money, EFI!
  8. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Q-jet will work
    670 truck avenger(don't be fooled and put the 770 on there it will be too much)
    projection EFI if it fits your budget
