what carb for a 454 bbc
Discussion in 'The Garage' started by 89Burben, Jul 28, 2006.
  1. 89Burben
    89Burben Registered Member
    Jan 3, 2005
    98
    CT
    i was mainly looking at the holley truck avenger 670 or 770 cfm
    Or edelbrocks thunder series AVS offroad carb which is only available in a 650 cfm.
    Just wanted some opinions on which carb is better for the offroad scene and how does the edelbrock carb work?
    Two of my other 4wheeling buds have the TruckAvenger carb and they seem to do well. I just dont want a carb that is going to be high maintenance
    What CFM would work best for my app?
    its a 454 .030 over with an edelbrock dual plane rpm air gap manifold, mild comp cam, and headers desktop dyno says 350 hp and 530 ft lbs of tq.
    any helps appreciated thanks
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Out of those I would take the truck avenger in 770 cfm. IMO its the best fit for you and is an easy carb to work on
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    what he said...:bow:
  4. 89Burben
    Jan 3, 2005
    98
    CT
    alrighty, does the 770 cfm holley have the same problems that ive read about with the hesitation and then some people had to return them or was that only for the 670 cfm one?
    As far as tuning the carb should it be good right outa the box like they say? or do you gotta fidel with it?
  5. RootBreaker
    Nov 29, 2001
    5,117
    173
    out of the box.. I dont think there are many carbs that will just bolt and go...
    also I dont know about the hesitations but that is an easy fix.... bigger accelerator pump and discharge nozzles... = more fuel..... but no hessitation
  6. 89Burben
    Jan 3, 2005
    98
    CT
    ok thanks for the info
  7. resurrected_jimmy
    May 23, 2005
    2,241
    There was a design change from the first run that came out. That problem has been fixed and if you have one of the problematic carbs Holley will replace it free of charge
  8. wicked87_k5
    wicked87_k5 1/2 ton status
    Aug 9, 2004
    235
    Little Falls,NJ... North
    What they said :D
