What caused my 205 to get stuck in 4-low?
Discussion in 'The Garage' started by fortcollinsram, Nov 18, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    as the designated driver tonight, I stopped by a hill on my way home to give my druck friends a little roller-coaster feeling in theier stomaches..I lock the hubs and put the case in 4 lo and crawled up the hill...I got to the top and tried to get the case out of 4 lo and it wouldn't budge...I put the tranny in neutral, unlocked the hubs, and rolled back and forth a bit and still wouldn't budge...usually it just requires a light jerk of the shifter and it shifts..so I decide to pull it a little hard and the bolt that holds the shifter in the adapter broke a chunk of the adapter off..so I drove home in Low range and removed the shifter and I pried the case out of 4 low with a pry bar...it pried pretty easily...so what gives...one idea I had is that my front drive shaft is an inch longer than it should be b/c I had it built with off-set Zero-Rated in mind to scoot my front axle forward a little bit..Is it possible that the driveshaft bottomed out and caused things to bind a bit in the case?I guess I can pull the case apart when I replace my adapter...
    Chris
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    My '85 K30 has this same "problem" to it sometimes, too. No clue what to tell you though.
  3. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    im not very sure if there is a linkage on those things, but try lubericateing it, or put a shifter extension on there, i know my np208 shifter isnt very long, but my sm465 shifter is, i dunno im just throwing this out in the open.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  4. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I recently went through the entire case about 3 weeks ago...I cleaned it, sandblased the case, cleaned all the bearings, all new seals, etc...it shifter smoothly up until tonight...keep in mind it was a STEEP hill...another 3-degrees steeper and I probably would've been backing down...could the case possible "lock" itself into gear? i dunno...I will get on swapping in a new adapter and I will see if it is better...like I said, it slid out of 4 low pretty easy using the prybar, which had a similar lever arm that the stock shifter does...
    87sm465np208 :
    If I had a 208, i'd be checking the shiter linkage..the 205 shifter is as simple as they come...the shifter is bolted directly to the adapter whar it =pivots and moves a plate that drives 2 shift rails in and out of the case...
    Chris
  5. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I had this similar problem this afternoon. I just put the truck in gear and rolled slowly until it went into neutral. I think my problem is that my home made shift rail plate is binding up. It might be possible that yours is worn a little and happened to get in a slightly different position than normal and hung up. And when you used the prybar it pulled both rails evenly.
  6. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    yeah, i think the reason that the shifter bolt lug ripped off the adapter is because I put to much muscle into the shfter bolt when tightening it a few weeks ago..the shifter was still rattleing and the bolt was getting tight...but like always, I just kept going...There is a crack in the lug off the adaptet that has a good bit of rust on it so it must have happened when I installed the shiter...and tonight when I tried to shift the think with my gorilla arms, it just brok off...
    Chris
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I use to have those problems!
    Now I always shift on-the-fly and gear changes are a snap.
    I drive it in 4lo till I need more gears. I then put the tranny in N and shift from 4lo to 4hi (or 2hi if I am going to hit pavement). This has always worked for me alot better then doing it while stopped.
  8. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    I do exactly what Triaged does. Makes it so much easier.
    Evan
  9. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I will try that...before this iproblem it always shifted smoothly, but somtimes I would have to "rock" the truck a bit to loosen so stuff up in the case until it shifted...
    Chris
