What causes backfiring??
Discussion in 'The Garage' started by CaveBlazin, Jan 14, 2004.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    My buddy has a 400sbc and he just had someone put a new carb on it and now its backfiring as he shuts it off. It will knock when he gets on the pedal a little. This just started after the carb change. Im sure its something easy (I HOPE!!) so what do I tell him other than take it back to the garage that put the carb on..
    Thanks,
    Spence
  2. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Check the timing on it.
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Could be wrong jets. 400's need bigger jets than a 350.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    2nd that.
    Check the firing order.
    Make sure the idle mixture is correct.
    Slow the idle down.
  5. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    he asked what backfiring is, and even if yall cut to the chase and fixed his problem, i'm still curious. my understanding of it is, its when the exhaust gas is still combusting as it goes out the exhaust port. am i correct?
  6. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    yeah is it poping up through the carb or out the tail pipe.
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    It blows the power vlaves out of a holley carb when it happens too.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Backfiring is caused by combustion happening when the valves are open.
  9. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    haha now ya tell me, needless to say I just replaced that /forums/images/graemlins/tongue.gif
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    advanced too far, retard it a little and also get vacuum guage and make sure idle manifold vacuum is within 18 to 22, if not then adjust timing more until it is within that range
  11. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Dang timing sounds about right cant believe I forgot that...
