What causes GM HEI coil failure?
Discussion in 'The Garage' started by madmike, Sep 25, 2006.
  1. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I acquired a freebie, 1983 K10, 305, SM465/NP208. When I got it, it wouldn't start, so I checked for spark at the plugs, there wasn't any. I put in a used coil I had laying around, and it fired right up. I thought, great! No money required! I put maybe 100 miles on it or so, and one day it stalled, and wouldn't start. Again, I checked for spark at the plug, and there wasn't any.
    Well, it was an unknown condition used coil I had thrown in there, so I thought that maybe it just failed because it was old. So, I bought a new one, threw it in, and the truck fired right up. I thought, great! She's good to go! That coil didn't last an afternoon, and there is no spark at the plug, so I know the coil went bad. Now I realize that something is causing the coils to fail. I checked the 'BAT' wire to the distributor cap, the wire is live when the key is on, and dead when the key is off, so I know the coil isn't energized when the truck is not in use.
    I tried looking at the wiring, from the fuse block down to the starter, and I see no obvious signs of damage. The fusible link wire to the distributor cap looked fine. There is a braided ground strap that runs from the firewall to the rear of the passenger side cylinder head, and another black ground wire from that point that seems to disappear into the wiring harness. That wire had cracked insulation, and there was quite a bit of green corrosion damage at that point. I went ahead and repaired that part of the wiring, but I'm not so sure that was the real problem anyway.
    Can a bad ground cause the coil to fail? I know the current has to complete a circuit. What about excessive voltage, like maybe the alternator is putting out too many volts (I did check it, it was 14.5-15 volts), but maybe it is spiking?
    I don't want to throw a third coil on there, not knowing how long it will last, and not being able to trust the truck. What causes a coil to fail?
  2. xpndbl3
    xpndbl3 1/2 ton status
    Jul 30, 2005
    510
    orland park, IL
    could be a faulty ignition module. Luckily HEI distributors are dime a dozen and very cheap to replace if you'd like an entirely new one.
  3. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    yeah..
    Could also be the pick up coil--often they fail only intermittently,after the engine warms up and gets hot..then after it cools off it will start and run again,at least for awhile--sometimes days,before acting up again!..can be a real butt pain to diagnose,since many other causes have similar symptoms,like corroded wiring for example...:crazy:
  4. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    Do you have the ground strap on the coil????
  5. madmike
    Jan 23, 2002
    496
    ohio
    I'm not a member, so I can't see the photo you attached. Where would a ground strap to the coil itself go? There are three wires that exit the side of the distributor, and plug into the bottom of the cap. Maybe one of them is a ground?
    The odd thing is, the distributor that was in the truck had a separate 4 wire lead, that plugged into the firewall. I wasn't able to set the timing with that distributor in it, so I replaced it with a common '75-'82 one, and then I was able to set the timing just fine.
    What's even stranger is that two coils have failed, one in each distributor, so I don't think it's a electronic ignition module, or the pickup. I'm leaning towards the wiring.
    Anybody else have an idea?
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I don't know if it applies here , but an old timer told me not to leave the vehicle turned on without it running . He said it nots good for the points/module/etc . I know better , but they still put accesory on the switch for a reason :D
  7. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    one time when my truck had points i decided to leave the radio on and the points fried, tried replacing them and it was easyer to go to HEI and it runs better and i can jam to the radio now!!!LOL
  8. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    I would guess the ignition module, there about $20.oo bucks at the parts store, and they are easy to replace
  9. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    how did you get a truck for free??? thats cool
  10. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    hmmm...
    You had an "EST" HEI distributor (Extended Spark Timing)--those had no vacuum advance unit,it was all done by the module,which has 5 or 7 pins,rather that the simpler 4 prong one in older HEI's....and you put an old style HEI back in?--that should be no problem,I did that to my 305 I had in the 79 C-10 I just sold recently,and it ran fine..
    All that style HEI requires is one "hot" wire to the "Bat +" terminal on the cap..the coil has a bent peice of flat steel, with a hook on one end, that goes under one bolt that holds the coil in, to ground it..usually it won't even start if that ground strap peice is left off..:crazy:
