what causes oil to blow from dip stick hole?
Discussion in 'The Garage' started by lazerus, Jul 14, 2003.
  1. lazerus
    lazerus Registered Member
    May 13, 2002
    51
    north texas
    hey, that rhymes /forums/images/graemlins/laugh.gif...
    anyway- Was working on the timing and taking short little drives around when I get back to garage the dipstick has been pushed about 1 inch out of the dip stick tube and oil has been coming out out of the top of the tube AND on the other side of the motor oil is being pushed out of the PCV breather filter that pushes into the valve cover...
    I first thought too much oil, but it reads on the full mark (not above it). The only thing I can think of off hand is I added an oil cooler but cant figure out what that has to do with it... /forums/images/graemlins/1zhelp.gif
    Thanks for the help!
  2. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    is your pcv valve good? when you shake it can you hear the check ball move? spary it with some brake clean or some carb n choke cleaner to get some of the gunk out and see if that helps. also check to make sure the line to the pcv is direct manifold vacumm, not ported from the carb.
    -Scott
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Thats a bad thing. Mine did that last year. I tried using two PCV's, one on each side, and it only got worse. It turned out to be a broken ring and a piston. Hope yours is a little better news.
  4. lazerus
    May 13, 2002
    51
    north texas
    I am out to check the PCV valve.... I have my fingers crossed that is it....
    thanks!
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Too much blowby. The ring's/cylinder's are worn allowing compression to leak past, causing excess pressure in the crankcase.
    For year's all vehicle's had a "roaddraft tube, meaning when vehicle was in motion it had negative crankcase pressure. When the ring's/cylinder's started to get worn, oil would blow out the dipstick tube. /forums/images/graemlins/eek.gif
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i had the problem one night at close to a hundred MPH(bad ju jue no oil that fast) but i got it shut off and coasted to a stop. added some oil and drove slowly to the parts store. checked my PCV valve and it was BAD. put a new one in and no more problems, ever.
    Grant
  7. lazerus
    May 13, 2002
    51
    north texas
    ahghhhghg. Doh. That PCV valve sounds good, looks good, and even works. I think this means bad stuff. /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif Also, I noticed that the PCV valve has fresh oil in it, I think it is sucking oil. Is this consistant with too much blowby/worn rings-cylinders?
  8. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    hate to burst your bubbles...but u cant tell if a PCV valve is good by shaking it. if u have n e doubt, replace it. they r supposed to b replaced every 18-20 thousand miles
    NITRO
