what causes surging with FI
Discussion in 'The Garage' started by big83chevy4x4, Mar 30, 2005.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    working on a 94 gmc safari with the vortec 4.3l. its been sitting for about 6 months waiting for me to finish the motor swap (talk about a PITA), fire it up, time it correctly. and the idle surge, sometimes it dies when it gets too low. if you put the slightest touch on the gas petal, it stops, but idles too high. i was told a bad fuel pump, could it be the 6-9 month old gas?
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    296
    Truckee, CA
    I was going to guess fuel pressure too, but old gas could definitely do it.
  3. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    oh yea, the fuel pump is 4 years old, AC Delco.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Bad gas, vacuume leak. dirty IAC, tps adjusted wrong, Clogged fuel filter. Lots of stuff to check before replacing the fuel pump.
    Have you checked trouble codes?
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    no codes, no vacuum leak, IAC is clean, tps is adjusted correctly, fuel filter... it was changed when we did the pump, probably should do it again.
    i just remembered that it takes a few seconds after you let off the gas for it to return to idle.
  6. Big Red
    Big Red 1/2 ton status
    Jan 9, 2003
    250
    Bristol, CT
    i bet its a combo of the bad gas and fuel filter. at advance i get a lot of poeple with the Astor/Safari vans that have that problem. though most don't let it sit for 6-9months. lol. just change the filter and i bet you'll be fine. :thumb:
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ok, ill get a FF tomorrow and put it on and put some new gas in it.
    if anyone has ever done a motor swap on a safari, you will know why it took my 6 months lol. its a very tight fit on everything.
  8. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I have read over on thridgen.org about this problem with tpi engines...Everyone says replace the CTS.
    Replace your Coolant Temp Sensor.. It's probably around $9.00 ?
    Or more fuel at idle might fix the surging, like fuel psi?
    Mine will surge when i first start it up sometimes... after a minute or two when it goes into closed loop its fine.
    My friends tpi vette surges at idle quite a bit also pretty much all the time, but both of our engines have cams so that might be part of it.
  9. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the coolant temp sender is new, i broke the old one off :crazy:
    it seems to be getting better (not doing it so much) the more it runs, maybe its just bad gas or gummed up filter. :dunno:
    also when driving for a while, 15 minutes or more, and stop at a light, it doesn't do it, but if it sits long enough it starts to do it.
  10. dyeager535
    26,982
    191
    Does it surge whether cold or hot?
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    both, but we have never gotten it hot for very long.
  12. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Usually when the MAP sensor goes bad it'll just run like **** but still run.
    Is the EGR valve not closing all the way?
