what causes the brake light to come on?
Discussion in '1992-Present Chevy & GMC models' started by Pookster, Oct 22, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    in my 92 pickup- the brake light will come on shortly after passing about 35mph- Is there anyway to diagnose whats tripping this?
  2. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Not sure. My 93 flickers because there isn't enough tension on the e-brake cable. One is busted & I haven't felt like replacing it. Try pulling up on the pedal w/your foot to see if that stops it. /forums/images/graemlins/confused.gif /forums/images/graemlins/dunno.gif
  3. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    body lift did mine in it stays on all the time but its adjusted correctly
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Could be an ABS problem. The lights also come on when low on fluid but that usually just stays on, not coming on after 35mph... I would have the codes read and it's most likely an ABS problem. But check your fluid level to be safe.
  5. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    could be, I know the ABS isnt functioning correctly. Heck, it isnt functioning at all. Could it be because the P.O put two different sized tires front and rear?
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    ABS only detects if the wheel has locked up or if it is spinning, I don't think that different size tires would matter. Is your 92 4 wheel ABS or just rear wheel ABS? If it's just rear wheel then it wouldn't know anything at all about the front tire size.
  7. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    If it has 4 wheel ABS, the different size tires between front and rear will throw a fault code at higher speeds. The smaller tires will be spinning at more RPM's then the larger ones and the ABS module will pick up on this and set a code.
