what causes your tires to do this?
Discussion in 'The Garage' started by chevy_mud_84, Jun 12, 2006.
  1. chevy_mud_84
    chevy_mud_84 Registered Member
    Feb 28, 2005
    89
    Brockville, ON, Canada
    What causes your tires to chop? cuz my brand new 35" mt's the centere lugs on the front are startin to kinda chop. like the tread wearing unevenly on each lug.
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    My friends did that and it was caused by an alignment issue.
    Ira
  3. chevy_mud_84
    Feb 28, 2005
    89
    cuz i know my truck needed wheel bearings and a new steering box, and i just got them all put in this week. so hopefully that fixs it. but i guess i might try and alignment.
  4. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    balance your tires
  5. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    rotated em lately?
  6. evo
    evo Registered Member
    Dec 11, 2002
    30
    oregon
    if you have them rotated regularly it helps
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Under inflated, over inflated or bad alignment will cause this.
  8. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    All of the afore mentioned, along with bad shocks. It happened on some tires I had on my old K5. Everything checked out ok.. turned out the shocks were just too old & probably weak. I changed them out and watched them for a while and the scalloped edges went away. No problems after that.
  9. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Warn parts......
  10. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    If the bearings are shot, it will cause abnormal wear.
  11. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    warn wheel bearings, not rotating(but I'm talking for like 15k miles), and worn ball out ball joints are the most common causes of choppy wear I see on a daily basis. Had one yesterday that was caused by bad alignment and both idler arms(IFS Chevy) were worn out.
  12. chevy_mud_84
    Feb 28, 2005
    89
    well the truck has a new steering box, new wheel bearings, ball joints on the one side, the tires are balanced, they are a radial tire, it has brand new shocks on it, new steering arms and end links and all those parts, the tires are at 35psi, and i just put these new tires on like a month ago, so maybe i should rotate them. but other then that i think im down to an alignement.
  13. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Is this your DD also? Heavy aggressive driving and braking could cause this also.
    I chewed up front tires driving pretty crazy in my younger days.
  14. chevy_mud_84
    Feb 28, 2005
    89
    yes this is my DD.
