what color RTV for gaskets... which ones dont eat up the metal
Discussion in 'The Garage' started by jjlaughner, Aug 22, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I have a brush on gasket maker from John Deere I use when I have a gasket of some type. I'm thinking for the diff covers laying a bead around the bolt holes and then a wide bead between the holes and letting it setup over night before installing. Anyone done this? /forums/images/graemlins/ears.gif
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    I am starting to use the Ultra-black stuff. Really just ran out of the regular gasketmaker tube sometime last year. Havent had anything eating up metal /forums/images/graemlins/thinking.gif .... have been using it to seal my oilpans and valve covers with no ill effects on the engines or ECM/sensor mumbo-jumbo.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Use blue RTV on diff covers. Make a circle around all the bolt holes and then connect them like you said. But, only let the blue RTV set up for around 10-15 minutes...definitely not over night.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i used to like the blue, but after i took my hubs off and the PO used it instead of an oring and it ate up the metal, i don't use it very much anymore
    im starting to like the black stuff though.
  5. Storm Trooper
    Nov 24, 2000
    4,640
    Check out Permatex Good Stuff, it works really good.
  6. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    You mean The Right Stuff?? yeah that is the shiznit.
  7. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    agreed /forums/images/graemlins/thumb.gif
  8. tree_entz
    tree_entz 1/2 ton status
    May 4, 2004
    141
    N. Vermont
    I've been told the black stuff is the most resistant to oil.
    (seal failure due to oil contact/ dirty surface when making seal, or general breakdown over time).
    could someone please explain the blue rtv breaking down metal???? it's just silicone based right??? /forums/images/graemlins/thinking.gif
  9. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    yeah but the silicon contains salt or acids and it pits the sealing surface. I usually use red for everything mainly because thats usually what I have. Never really had any problems with it either. I just couldn't remember which was which. Looks like the blue stuff is the one I want to avoid. I think I have a black RTV and some red left if its not dried up.
    What about the copper RTV is that for mainly intakes or hot areas?
  10. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have started using Ultra Grey. Seems to work well. I usually use Ultra Black for Diff covers, Ultra copper for everything else. Blue I use mostly for water pumps, tstats, etc.
    I used Ultra Grey for my tcase reseal because Ultra copper got eaten by ATF.
    Harley
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    went to the the permatex site...
    Permatex® the Right Stuff® Gasket Maker
    Return equipment to service immediately when you make leakproof gaskets in just one minute with the Right Stuff.® This latest elastomeric rubber gasket technology is blowout resistant and outperforms pre-cut gaskets. Specified on production lines by GM, Ford, Daimler-Chrysler and Mercedes-Benz. Temperature range -75°F to 450°F; (-60°C to 232°C) continuous, 500°F (260°C) intermittent; resists ATF, coolant, oil and other shop fluids. Protects against leaks caused by vibration and thermal expansion. Sensor-safe.
    Suggested Applications:
    Automotive and marine gaskets, valve covers, gearbox covers, pumps, compressors, oil pans, thermostat housings, water pumps
    PERMATEX® ULTRA BLACK® Gasket Maker
    For dealership warranty requirements, insures extended drivetrain warranties compliance. Fast-curing formula. Sensor-safe, low odor, non-corrosive. Meets performance specs of OE silicone gaskets. Retains high flexibility, oil resistance properties through use of a patented adhesion system. Temperature range -75°F to 625°F intermittent; resists auto and shop fluids and vibration. Also available in AUTOMATIC TUBE® dispenser.
    Valve covers, oil pans, intake manifold end seals, timing covers, transmission pans
    PERMATEX® ULTRA GREY® Gasket Maker
    Designed for high torque applications (predominantly Japanese designs) requiring a unique RTV gasket. Exceeds manufacturers’ performance requirements. Low odor, non-corrosive. Outstanding oil resistance. Guaranteed not to leak. Temperature range -75°F to 625°F intermittent; resists auto and shop fluids and vibration.
    Valve covers, oil pans, intake manifold end seals, timing covers, water pumps, thermostat housings
    PERMATEX® ULTRA COPPER® Hi-Temp RTV Silicone Gasket Maker
    For 4-cylinder, turbocharged or high-performance engines. The most advanced, high temperature RTV silicone gasket available. Sensor-safe, low odor, non-corrosive. Superior adhesion. Three times more oil resistant than conventional silicones; eight times more flexible than cut gaskets. Temperature range -75°F to 700°F intermittent; resists auto and shop fluids and vibration.
    Exhaust manifolds/headers, valve covers, oil pans, timing covers, water pumps, thermostat housings
    PERMATEX® Sensor Safe Blue RTV Silicone Gasket Maker
    The original Blue. Will not foul oxygen sensors. Replaces almost any cut gasket. Makes reliable "formed-in-place" gaskets that resist cracking, shrinking and migrating. Coats pre-cut gaskets to increase reliability. Temperature range -65°F to 500°F intermittent; resists auto and shop fluids. First generation 1970-1980 gasket maker. Also available in AUTOMATIC TUBE® dispenser.
    Valve covers, oil pans, timing covers, water pumps, thermostat housings, transmission pans
    PERMATEX® ULTRA BLUE® No Leak RTV Silicone Gasket Maker
    PERMATEX® Ultra silicones were developed to meet today’s technology changes. Sensor-safe, low odor, non-corrosive. Outstanding oil resistance and joint movement values. Eight times more flexible than cork/composite gaskets; three times more oil resistant than conventional silicones. Temper-ature range -75°F to 500°F intermittent; resists auto and shop fluids and vibration.
    Valve covers, oil pans, timing covers, transmission pans, differential covers
    /forums/images/graemlins/thinking.gif none of these say avoid such and such metals
    Doesn't even list the red type
  12. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    HMMMM /forums/images/graemlins/thinking.gif I've been using ultra copper on everything for about a year now including my tranny pan and t-case adaptor. Haven't had any issues yet /forums/images/graemlins/dunno.gif
  13. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    I noticed the regular blue stuff doesnt say "non corrossive"in the listing --while the others did,this leads me to beleive the"non corrosive" ones wont eat the metal.I know of one person who used the regular blue silicone to seal his leaky windsheild a few years ago--now you can put your hand in the holes in the cab where he sealed it!. /forums/images/graemlins/yikes.gifI guess the vinegar they warn you about on the package makes a good acid that will eat the metal after time--probably not much of an issue if its drowned in oil all the time,like a valve cover though. /forums/images/graemlins/crazy.gif
