What comes first body-suspension
Discussion in 'The Garage' started by airassault, Mar 26, 2004.
  1. airassault
    airassault Registered Member
    Mar 25, 2004
    6
    Scottsville KY
    I need some tip tricks. I have a 4 in. suspension w/rear springs, and a 3 in. body lift. What is the best way to install this, what order. Oh and just a warning, if you order a kit from rough country they ship it in pieces, I mean 2 springs one day and 3 shocks the next etc.
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/rotfl.gif
    I don't think it matters with the order to install it. /forums/images/graemlins/dunno.gif
  3. barryb
    barryb Registered Member
    Oct 15, 2003
    51
    Springfield MO
    im the type of guy to knock out the hard stuff first, then its all down hill .... so it depends ....... oh ya .. what he said
  4. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i did the suspension first,that way the body is higher for you and your friends to grab. /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  5. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    My lift kit came in a few boxes also, but it all arrived at the same time. I bought my kit from a vendor on ebay though, maybe that's why /forums/images/graemlins/dunno.gif
    I would do the body lift first because you'll have better luck lifting the body off the frame while the frame is closer to the ground. The suspension lift should be second since it doesn't matter how high your body is, you'll be supporting the truck by the frame. I do have one question though, why 4" suspension and 3" body instead of just a 6" suspension lift and maybe a 1" body lift? You'll need brake hoses and steering correction with the 4" and you'll most likely have to have a driveshaft or 2 made. The 6" kit would have necessitated the same parts but eliminated that tall body lift. Anyways, I'm not trying to tell you your stuff is junk, I personally would have done it different though. Good luck with the projects /forums/images/graemlins/thumb.gif
  6. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I don't like to break my back so I used multiple jacks and wood to raise the body off the frame. My spine thanked me by letting me grow to be 6'4" /forums/images/graemlins/whistling.gif
  7. boggerless
    May 26, 2003
    22,728
    96
    every day the lightest thing i pick up is 80lbs and thats about 300+ times a day, so weight doesn't mean to much to me. as tall as you are i'd think you would want the body higher. /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Why don't you just do the suspension lift and forget the body lift. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  9. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    I'm running a 4" and 33's and I sit just under 7 feet tall, perfect in my opinion, then just trim the fenders as needed for bigger tires, 35's in my case. 33's fit perfect on my 15x8s no rubbing but its close under full flex, 35s will require some light trimming on the back side of the fender.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have 6" total or so right now. I wish I'd saved my 4" springs so I could go back to what I started with--a 4" suspension lift.
  11. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    I think if your going to be doing trails and rocks 4" is best, that way you keep a low center of gravity to help reduce risk of flopping it over. Thats one reason I went with 4" and right now I got 18" of clearance to the skid-plate, thats good enough for me right now.
