what compression ratio?
Discussion in 'The Garage' started by chevystepside, Jul 14, 2003.
  1. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    what is the highest compression ratio that a tbi 87 350cid engine be built to with no computer mods?
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    running what octane? after market heads? headers? stock cam?
  3. chevystepside
    Sep 23, 2002
    147
    leadville colo
    regular pump gas or mid grade.stock 76cc tbi heads with malley budget performance valves. cam is going to be a dual energy 12-249-4 comp cam 206deg 212deg .434intake .444exhaust.
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    9.2 with cast iron head's
    9.7 with aluminum head's
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    is that cam TBI-approved? I'd say 9.5 with a WELL tunes engine and mid-grade, with 92 in it at any altitude.
  6. chevystepside
    Sep 23, 2002
    147
    leadville colo
    jegs said that the cam is ok for tbi motors.coolthanks for the info. now to pick the pstons for the compressions between 9.0 to 1 or 9.5 to 1
  7. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    The compression ratio will depend on the cam too. Overlap.
  8. chevystepside
    Sep 23, 2002
    147
    leadville colo
    the cam is comp 12-249-4 dual energy 206deg 212deg 434int .444exh 112deg. i,m looking at keith black silvolite hypereutectic pistons with +6.25cc 4 valve reliefs. they say that with a 76cc chamber head that the compression will be 9.2 to 1. head gaskets are going to be felpro .o41"thick.
