What controls tire bounce/hop?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Can Can, Mar 31, 2002.
  1. Can Can
    15,555
    151
    Cochrane, Alberta, Canada
    Is it shocks or springs that keep the tire from bouncing/hopping on rough roads? I thought it was shocks but today somebody told me that weak springs can allow the tire to hop as well............Is this true?
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Well it might be a combo of shocks,springs,and sway bar. Most likely shocks.
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Shocks are the biggie - I've seen some really "custom" spring engineering on the buggy classes, but a good set of shocks makes up for it and keeps them glued to the ground.
  4. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    Its the spring that actually moves and causes the bouncing, but the shocks essentially dampen that motion, both on the compression and the rebound of the spring's movement. So if the shocks are worn out or don't have enough dampening capability, then the bouncing will be more prevalent. The stiffer the spring, the more bouncing there will be, too. The stiffness of the spring should be somewhat matched to the dampening of the shock. Hope this helps.
    Will
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    If the springs are stiff they will not bounce as bad as if they were very soft springs. Shocks are what control the bounce not the spring. Springs support the weight of the vehicle, shocks dampen the bounce.
  6. 72THING
    Nov 26, 2001
    501
    Ranburne, AL
    4X4HIGH, you explained it better than I did. I sorta had it backwards. Oh well, sometimes its hard for me to explain stuff. Thanks.
    Will
