what converter should I use for my 700r4
Discussion in 'The Garage' started by 4wheelattitude, Aug 5, 2005.
  1. 4wheelattitude
    4wheelattitude 1/2 ton status
    Aug 5, 2005
    145
    central Illinois
    I really don't know where to go with this? I going to put a 700r4 in the place of my manual 3sp in my 1970 GMC short bed. 205 transfer case and 3:08 gears. Does anybody know what converter I may want to install in the place of the stock lock-up converter? I've been reading allot on the internet and now even more confused!
  2. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    First you need to ask yourself what will I be doing with this truck. If you are mudding you may want a higher stall then stock. If you are rock crawling you want a stall speed that is lower than stock. If this is a daily driver I would go with a stock converter maby a few hundred RPMS above stock.
    If your engine is camed then go bigger then stock. Find something that will work real will with your trucks set up.
    I have a converter for a 700R4 I will sell to you real cheap. It cam out of my 1986 K5 with a 350.
    Adam
  3. 4wheelattitude
    Aug 5, 2005
    145
    central Illinois
    700R4 converter
    Thanks for the quick reply Adam. The truck will not be leaving pavement with exception to the dirt roads in southern Colorado. Primarily a daily driver/show truck. I love to drive and show it off. I combined a 350 and a 327 and came out with a 333. A larger cam and dome pistons. A little higher RPM and allot more torque. Willy
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello
    how big was your cam?
    Adam
  5. 4wheelattitude
    Aug 5, 2005
    145
    central Illinois
    700R4 converter
    ? I can't remeber the specs?? I was told it was a number 2 rv cam. If that makes any sence? It's been a while since the build, but I may be able to find the paper work.
    Willy
  6. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    I think if you ran a coverter that was around stock-1700 stall you should be fine. I think I heard that the stock stall speed on a most of your trucks is 1400.
    Adam
  7. 4wheelattitude
    Aug 5, 2005
    145
    central Illinois
    Do you know anything about non computer lock-ups?
  8. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
  9. 4wheelattitude
    Aug 5, 2005
    145
    central Illinois
    Thanks! I'll check it out. There are so many option. Who knows what to go with?
  10. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    give a big name tranny builder place a call. i know a guy who had art carr build him a tranny and converter based on his cam. give them a call, they would know best.
  11. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    i WOULDN'T RUN ANY EXTRA STALL WITH THOSE 3.08 GEARS IN THERE....
  12. 4wheelattitude
    Aug 5, 2005
    145
    central Illinois
    Do you think the 3:08's are to much?
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    no... you came out with a 327 that has been bored .040"...
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    no, unless you're planning a tire bigger than 27" tall.
  15. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    get a new lockup converter from bowtie along with there lockup kit. i think the 1800rpm HD converter is the one they'll recommend. i wouldnt get a used lockup converter.
