What could cause a massive u-joint failure??
Discussion in 'The Garage' started by 85mudblazin, Jul 17, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Tonight I was stopped at a stop sign about to turn right and when I pushed the gas my blazer kindove lurched and a loud bang occured, I jump out look under the truck and there is no driveshaft I turn around and there it is a about 6ft away I look at it and both u-joints were broke off at the caps, Luckly I was about a 1/4 mile away from my house so I drove home in 4wd with tranny fluid pooring out, WHAT COULD HAVE CAUSED THIS?????
    Next question is what u-joint is in a rear driveshaft out of a 1985 blazer with a 208 t-case and a 10b rear??
    Much thanks.
    -Chris
    P.S: I will have carnage pics tomorrow!!!
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Catastrophic failure is caused 99.999999999999999% of the time by the yokes binding.
    2-3011 is the part number you're looking for, 2-3012 for greasable through the cap if desired.
  3. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Is the other 0.000000000000001% from popping wheelies?
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    What would cause the yoke to bind?? I have herd a little noise during sstoping and starting you think this had something to do with it?? Could there have been a crack in a u-joint and it just all of a sudden gave out??
    -Chris
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That other minor percentage is the people that actually have enough torque to make a u joint that is not binding fail, which is pretty rare without a severe shock load.
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    What size are the rear u-joints??
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Saginaw S44. Comparable in size to a Spicer 1330.
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Which would be the beter brand to buy?? or will only the saginaw s44 fit??
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Saginaw S44 is the size of the joint. You can buy whatever brand you want.
  10. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Is there any one brand that is better than the other??
  11. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
  12. ugly_blazer
    Apr 12, 2004
    1,214
    Spicer
    Ya, what he said /forums/images/graemlins/thumb.gif
  13. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    so can I just take those parts #'s to say napa and tell them I want spicer brand??
  14. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    You need to find a parts store or driveline store that carries Spicer. Not all parts stores can get them. Even less stock them.
    Harley
  15. ugly_blazer
    Apr 12, 2004
    1,214
    They may not be able to get spicer, you can always ask them though. They should be able to cross reference the number that Tim gave you.
  16. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    First off; have you been having problems with breaking u-joints or is this the first time?
    Second; is the original driveline that came with your truck?
    Thirdly; what modifications have you done to your truck? Your driveline angles may be wrong.
    Fourthly; you may have damaged your driveline in some way prior to this incident and it finally gave out.
    If I were you, I would take the driveline into a shop and have it checked out for damage and possibly have it balanced.
    Before you do however, I would take measurements to make sure your driveline is the correct length. Here is a site; http://www.dennysdriveshaft.com/html/how_to_measure.html
    The easiest thing to do is just replace your u-joints; however you still need to find out why they broke in the first place. The above is all just for preventive measures.
    /forums/images/graemlins/peace.gif
  17. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    This is the first time this has ever happened as you can tell by my lack of knowledge, I have a 4" lift and my angles were off and I had a vibration so I put shims in and that solved everything so my angles are good, so the only thing that I can think of is that the u-joint was damaged sometime and then it just gave out.
    -Chris
  18. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I am saving up to buy a HAD cv shaft so I will prolly just replace the u-joints and hopefully they will last about a month, I dont see why they wouldnt, they have lasted for about 1 year which is when I had them replaced when I bought it.
  19. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    that doesn't sound right to me for some reason /forums/images/graemlins/thinking.gif
    The three I lost had nothing to do with bind, and what about operating angle and wear on the needle bearings? Usually something that happens all the sudded is far from sudden at all and probably had signs that it was getting worn or was damaged before it failed. Most people interpret these things as all the sudden but loud stereos or not paying attention to the sounds your truck makes might have something to do with it /forums/images/graemlins/dunno.gif /forums/images/graemlins/deal.gif
  20. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    -Chris
    Did you also lower the t-case down when you did that?
