What could cause this?
Discussion in 'The Garage' started by Wingnutt, Oct 2, 2004.
  1. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    I replaced the bearings and one rotor (the right side rotor)this morning, and now when I hit the brakes, not only does it pull to the left, but at slower speeds the wheel turns about 30 degrees to the left /forums/images/graemlins/yikes.gif. When I let off the brakes at a stop, the wheel will turn back to the left enough for it to be where it's supposed to be /forums/images/graemlins/screwy.gif. Any ideas? TIA
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    sounds like you might have put it on to tight or to lose
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    That is your problem right there. Did you replace any pads? You really need to replace rotors in pairs, and put in new pads on both sides at the same time.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    something on the right side is preventing it from working
    did you damage the lines?
    were the caliper guide pins free to move?
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    when you put on the new rotor, dont they come w/ a protective coating (oil or something) on em? Were you sure to hit it w/ some brake cleaner to eat that off?
  6. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    To sum up your problem, I would say your left brake is working normaly, and your right brake is not, which is why it is pulling to the left. You probably put somthing together incorrectly on the right brake.
  7. Wingnutt
    Feb 20, 2000
    324
    NOVA
    Thanks for the replys. I guess tomorrow's project will be to replace that left rotor, and recheck everything.
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think it would be more prudent to fix the right side and figure out what you did wrong before you carry onto the left
  9. Wingnutt
    Feb 20, 2000
    324
    NOVA
    Well the brake project has to be put off for a day or two seeing as how I had to put my boat into the garage for some much needed maintance.
    I forgot to add that the pull to the left is VERY minor and only noticable when going very slowly. I did a quick check this morning and everythings "looks" OK and the caliper pins are not binding. I'll post a followup after replacing the rotor.
