What could cause this?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89Blazin, Apr 5, 2001.
  1. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    Me and Bondo have the same problem. I've got an 89, he's got a 90.... 350TBI/700R. With the cruise control on, doing 70 down the road, I come to an incline and loose 15 MPH before she drops down into drive. The cruise is pullin my acc. pedal in, but seems way too slow of a response. Bondo has been through all his cruise components and still has the problem. I have a new cruise lever/swithch in mine.
    Could it be something like the throttle position sensor? Or is the cruise a closed loop w/o the sensor? Sensor only feeds the ECM?
    Ideas?
    85 Burb and an 89 Blazer
    One just for fun, one simply for pleazer
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Probably just a quirk of the FI Blazer. Blazer's do tons of wierd stuff when its in good working order. In the morning the shoot out water and soot. The speedometer needle likes to shake. The wipers go on like they were possosed. The slip yoke on all the np-208/241s leak. I wouldn't be worried about it because you'll give yourself gray hairs from worry.
  3. 89Blazin
    Mar 20, 2001
    134
    midwest KC area
    Thanks Blazer Boy....it's probably the windshield wipers or speedometer causin it? Wow...no wonder under the dash looks like a birds nest of wiring....lol
    See you're in SUX....go there for busineess on occasion. Love the smell of IBP...makes me hungry for hamburgers....
  4. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    I have an '89 (Stock 350, 700R4, 3:73's, 33" tires) , and when I have cruise control on at that speed, it only drops 1-3 mph on a low to moderate incline. I don't know what's wrong with your cruise control, but it isn't functioning normally. Hope this gives you an idea of how it should perform. Good Luck.
    Did a test for you guys today. I crossed the San Mateo Bridge (in the SF Bay Area), which is level from the Hayward side for the first 2/3rds, and then has a sizeable rise or hump in the last 1/3rd (The bridge is about 7 miles long). While on level road, in OD, I set the cruise at exactly 65 mph indicated (69 mph corrected for tire size error). On the rise I lost 2 mph (the torque converter unlocked), and on the way down the other side I gained 1 mph (the torque converter locked). When I reached the level stretch on the San Mateo side, it returned to 65 on the speedometer.
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".<P ID="edit"><FONT SIZE=-1>Edited by Gandolf on 04/06/01 02:37 AM (server time).</FONT></P>
  5. LittleJimmy
    LittleJimmy 1/2 ton status
    Feb 16, 2001
    220
    Channahon IL
    I would check all your vacume lines. You will be amazed at the difference if you go through and take the time to just go and get some new lines and replace the old ones. The cruise runs off some vacume lines... Later LittleJimmy....
  6. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Hey 89Blazin, check you other post on this subject, I just wrote a mini-novel there...
    [​IMG] Semper Maintenance!
  7. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    I checked into this and they blame it on the tire size to gear ratio tweaking the speed readings for the cruise control to fix it they said to regear to the same rpm as stock and get a speedo gear.
    88k5 silverado w4"lift soon to have <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
  8. Bondo
    Bondo 1/2 ton status
    193
    Bath, NY
    I replaced all of the vacuum lines, the servo, and the turn signal lever/cruise switch in mine and none of it worked. The gearing thing won't work for me as I still have stock tires and gears. It has to be something else........
    Any other ideas?
    BONDO WILL FIX ANYTHING!!!
  9. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I would do a vacuum test on the servo... new or not... also would check the the entire vac system... does it hold when the symptoms hit? Hook a gauge up and go driving... Another thought is proper kickdown and throttle cables adjustments. Last of all I'd drive it while a metter is hooked up measureing the speed sensor if nothing else worked, but I would lean towards the other items.
    1987 Chevy K5 Blazer- 350 TBI
  10. Bondo
    193
    Bath, NY
    My new servo has been tested and is fine. The vac system tests fine as well. How do you check the kickdown and throttle cable adjustments?
  11. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    electrically tested? mechanically tested? or vacuum tested... I suggest the latter. it may be leaking a slight bit. You can check the linkage by having someone nail the accelerator to the floor. The kick down is a TV and has a tab/braket you adjust al;l the way back.
  12. NewK5Guy
    NewK5Guy 1/2 ton status
    Mar 2, 2001
    556
    Alexandria, VA
    So you say when you get to an incline, it won't downshift? Perhaps it isn't your cruise causing the problem.....
    Yes, cruise is pulling the acc pedal down to give the engine more revs to pull up the incline. But, you say it drops almost 15 mph before it downshifts? I'm afraid that sounds like a tranny problem. Cruise only holds the throttle plate at a preset position to maintain the associated engine rpm. This in turn, holds your speed. Cruise is nothing more than an automatic acc pedal. Try this:
    On that same stretch of hwy, drive along as steady as you can without cruise. Just keep your foot on the gas. When you hit the incline, slowly apply the acc pedal until the tranny downshifts. I bet you'll lose about 15mph before it does.
    If I'm anywhere near right(and I'm usually not), it sounds like the throttle valve is out of adjustment(I'm pretty sure the 700r4's had them) or the converter won't come out of lockup. My 84 700r4 is doing that now. No matter I have a diesel. When the mph drops, my tranny begins to shudder because it won't back out of lockup. Instead, I have to press the pedal until it downshifts to 3rd. If you can feel cruise pulling your pedal down, it's working fine. It only has one connection and that's to the throttle plate. My Ford AOD had a similar problem being reluctant to downshift.
  13. Bondo
    193
    Bath, NY
    No, my tranny works fine. It'll downshift geat when holding the pedal at the same spot with your foot when coming to a hill, just not with the cruise. Also, theres no vibration, shifts are smooth, no noises, etc. It has done it since I bought the truck two years and 50,000 miles ago. Seems if there was a tranny problem I would've known it by now. As for the servo being tested, it was both vacuum and electrically tested and checks out fine.
  14. 89Blazin
    Mar 20, 2001
    134
    midwest KC area
    Ditto Bondo....great shifts, downshifts fine with cruise if the hill is steep (Bondo...u 2 ?).....a gradual hill with cruise seems my only nusance... I think my TC is staying locked.
  15. Bondo
    193
    Bath, NY
    Yeah, same thing with mine. Just seems to be some little quirk.
  16. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    The TV cable need adjustment? Locked in OD maybe the engine just lugs until it finally downshifts .. it's a simple adjustment if its out and easy to check.
  17. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Does your tranny shift out of lock up, when accelerating or going up a hill? That is when out of cruise?
  18. Gandolf
    Aug 8, 2000
    764
    SF Bay Area
    Has anyone solved the problem yet?
