What could it be???
Discussion in 'The Garage' started by blazen91, Aug 22, 2003.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    88 one ton with a 454(fuel injection). I just went to start it and it wouldn't fire. Checked for spark at the coil and all is well, but not getting any spark at the plugs. (New wires)Is it just a cap and roter gone bad, or are there places to look as well? Thanks for the help.
  2. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    If its HEI, check to see that the two clips on the drivers side (i think) are hooked up. Had the same problem after a tune up. Once I found it, made me feel really stupid...only took 2 hours. /forums/images/graemlins/eek.gif
    Kris
  3. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I had the same problem. Check the module. I had my truck running then had to go inside to get something and when I got back it was not running. /forums/images/graemlins/eek.gif
  4. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I guess I should have said what it is..... It is not HEI. Has the seperate coil. (If it makes you feel better, I did the same thing on my Burb.)
  5. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Check the module.
    If was the module, would I be getting a spark at the coil? /forums/images/graemlins/confused.gif
  6. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    It should still have a module, right? /forums/images/graemlins/confused.gif
  7. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    No the module is the little back thing under the rotor the has plugs on each ends. /forums/images/graemlins/thumb.gif
    I should have waited longer for you the post.
