what custom parts do you need to clock 208
Discussion in 'The Garage' started by 85mudbogger, Feb 19, 2007.
  1. 85mudbogger
    85mudbogger 1/2 ton status
    Feb 5, 2007
    226
    missouri
    how do you clock a 208 what parts do you need my d shaft should work still i have to change it out anyway cus i busted the chain and pushed it out the top of the case so was just wantin info on this im gonna have to space it up away from the crossmember if i dont clock it cus the cv is rubbin on the xmember and how would the shifter work out:confused:
  2. jfaulk
    jfaulk Registered Member
    Dec 3, 2006
    60
    NC
    I hate to answer without having done the swap myself, but from what I've read on this site, you just need to get a clocking ring. You can get that from DIY4X.com. Depending on how high up you clock it, you might have to cut your floor some to make some space for the top of the case. Might also have to modify you seat bracket. Like I said, I haven't done this myself yet so there's probably something I left out. Hope this helps.
  3. cwn anwyn
    cwn anwyn 1/2 ton status Premium Member
    Oct 30, 2002
    1,268
    6
    Falcon CO
    Clocking ring.
    Cut hole in floor (depends on how high you clock it):D .
    I had to bend the linkage a bit since I clocked my case as high as it could go. I also had to make a square shaft since it was to short. But that was more than likely from the 52" swap.:D
    Z
  4. 85mudbogger
    Feb 5, 2007
    226
    missouri
    Got a 3 inch body lift so i shouldnt have any floor issues thanks looks like its very easy to do
