What degree of shim do I need?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by outlaw612, Sep 4, 2001.
  1. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Im gonna be installing my 4" lift this weekend. Also a 14bolt will be going in the rear.
    What degree of shim should I run?Should I run them in the front and rear? Ill be doing front springs and a rear shackle flip. Ive been told I maynot need to shim the rear, but I dont want to have to take it back apart to put a shim in later if I have vibrations. What if I decide on a 6" lift, then how much shim? Would 6 degrees work for both? Thanks.
  2. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    If you use the shackle flip you shouldn't need any shims in the rear. A rule of thumb that has worked for me is 1 degree per inch of lift. Remember that shimming the front takes away caster and will cause poor steering. Factory caster is 8 degrees and I wouldn't shim the front more than 6 degrees leaving you with 2 degrees of caster.
    <font color=green>Steve Frisbie</font color=green>
  3. outlaw612
    Feb 11, 2001
    2,342
    So should you run equal amounts of shims on both fron and rear or should I leave the rear alone and shim the front since the front has springs and the rear is going with the flip? Also, if I run 6" front and a flip with a 2" block in the rear would 4degrees in the front and 2 degrees in the rear sound right?
    Thanks for your help.
  4. i have a rear flip and 4" front springs. i had to shim the rear cause after the shackle flip the pinion pointed up too high. i used 2.5 degree shims but i think i really need 4s. the front seems to be fine to me. i used to have a blazer with a 6" lift and shimmed the front 4 degrees and it cured the drive line problem i was having, but i had bad bump steer. hope this helps.
    <font color=blue>American Pie 2-"Have you seen my flute?" "Yeah, I stuffed it in your box."</font color=blue>
  5. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Best way to tell is to just get an angle finder from Snap-on they are only 25 dollars adn they kick ass. Install everything check your angles and then you can be absolutely sure since no ones blazer appears to be exactly like others.
    tRustyk5 for President!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  6. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
