What did I do?
Discussion in 'The Garage' started by UseYourBlinker, Jul 1, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    After Blazer-fest my steering wheel is not centered. I have to hold the wheel almost half a turn to the right,ust to be able to drive straight. What did I do? All the steering componet's look good. Nothing bent. /forums/images/icons/confused.gif
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Well I would say that you knocked it out of alinment or bent the tierod ??? You can center the wheel again by loosening the 2 bolts that hold the clampa on the I think drag link (i think that's what it is) then with a pipe wrench turn the middle rod(make sure your wheels are pointed straight first not the steering wheel)untill you see the wheel back to the center....mike
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Check for cracks in the frame around the steering box VERY closely. Something had to move or bend for that to happen.
  4. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Maybe you rolled....? /forums/images/icons/blush.gif
    My steering is doing the same thing. And I've had that same experience on previous off roading trips. Maybe I'm just not tightening those draglink bolts enough?
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Also check the torque on the front u bolts.If they are a little loose the front axle can move around a little and cause that problem /forums/images/icons/grin.gif
  6. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    My truck was pulling when i was braking off and on on the way home i figure ill clean everything out real good and take it from there. I got a spare tie rod if you want it. Ill trade you for the trim. Give me a call if you want some help this week.
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the draglink coupler piece bent a little on you.
    it is very soft
