what did i find?
Discussion in 'The Garage' started by stizkidz, Feb 24, 2005.
  1. stizkidz
    stizkidz 1/2 ton status
    Nov 11, 2004
    219
    near Atlantic City, NJ
    Went with a friend today to this guy's private junkyard. I found: a 65-68 (not exactly sure of year) 1 ton Chevy frame. It is sitting on wheels/tires has both rears on stock suspension and has the manual trans/transfer case which I was told is the factory original equipment. I'm guessing it has a 14bff and dana 60 front? I'm no expert on 60's but the steering arm was held on by 4 bolts. I am not really sure what to look for as far as kingpins but what I saw was unlike anything I had ever seen before... I am curious as to what the tranny/case is but I know that it had dual PTO's. The guy wanted $500 for the whole thing. Good deal?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Dana 60 wasn't available in Chevys in those years. Not in the front anyway. If it was it would have been closed knuckle I believe. The 60 we all use and look for didn't come around till I think like 74.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    77..
    if its a 72 older chassis then the top lip of frame rail near engine mount tree wlll be bent up some, cant miss it, and rails in front are a little bit narrower channel than 73-up too
  4. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    GM started using the dana 60 front in late '76 as a '77 model (perhaps a few '76s as well, who knows). Dodge and International both started with them in '75, so GM was a couple years behind. GM never used the closed knuckle D60 or D70 fronts like Dodge and IH did.
    That being said, if its from the 60s and is 1 ton 4x4, it has a modified Eaton rear axle up front (should have Napco cast into one of the axletubes facing forward, should be easy to spot). It will have a matching Eaton rearend. If the tranny is correct, it should be a SM420 4 speed which only has 1 pto port. The transfer case will be divorced, either a Dana 23 or 24 (one was Ford driver drop, one was pass drop, I forget which is which) or a Rockwell T221. Post some pics if you can.
  5. stizkidz
    Nov 11, 2004
    219
    I was told that everything on the frame as it sits is stock. The transfer case was definitely not divorced and had 2 PTOs, so I don't know what it is. Is that sm420 a good trans compared to the 465? What is the difference?
