what did the NV4500 come in?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JunkYardCrawler, Nov 11, 2001.
  1. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    i looking to swap out to this and i need to know what to look in to find it.
    i blew my main seal.
    now my brain leaks
  2. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    THe NV4500 came stock in the 1993 and on Chevy pickups, as well as te 1993 and on Dodges. the 2 have slightly different input, and outputs, and the different years have different gear ratio's in them.
    -Rich
    My truck isn't ugly, you have a skewed sense of beauty
    <font color=blue>2007 Ford XLS++ intrepid Ram Superduty 7000 R-type's suck</font color=blue>
  3. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    really that new?
    now my brain leaks
  4. Ddragggon
    Apr 25, 2001
    2,657
    yep, they might even be newer.... the SM465 lasted from 1972 to 1988 or so. then it was replaced with the Gertrag 5 speed for a few years... then New Venture gear, a joint venture between chrystler, and GM came out with the NV4500, and a 6 speed prototype then called the 4600, now called the 5600 or 6500.
    good luck puting one in there,
    -Rich
  5. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    thanx
    now my brain leaks
  6. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Dodge started using the 4500 in '94. The 6 spd is the 5600; 5th is 1:1.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  7. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    When did they start with the six speed? Funny we don't hear more about that. Do know what GM calls the 5 &amp; 6spds? MM83?
    Real trucks don't have spark plugs!
  8. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    Dodge started the 6 spd somewhere around the end of '99. It was only put in a small # of trucks, due to reliability and prodution issues. When the HO cummins came out, (2000?), it was only available with the HO (as far as diesels, dunno about gas), and the HO was only available with the 6 spd.
    I saw somebody advertising a conversion to the 6 spd from the 4500, was pricey, don't remember who (standard trans, maybe?).
    Pete
  9. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I think the 93-94 GM versions had the first gear ratio of over 6:1, but have heard that these first couple of years had some noise and other small problems, so GM changed that in 95, and went with the same as Dodge on 1st gear ratio ( I think 5.6 or so to 1). Really nice trannies if you can make the driveline angles work for you...should be able to pull it off, though!
  10. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Hey, I ran accross this on the Pirate4x4 board.
    http://coloradok5.com/gallery/K5Jungle
  11. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    <a target="_blank" href=http://www.pirate4x4.com/forum/showthread.php?s=&amp;threadid=12516>NV4500</a>
    He's in AZ too
    FIXED?<P ID="edit"><FONT class="small">Edited by SAVAGE1 on 11/12/01 06:43 PM.</FONT></P>
  12. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    i get an invaled thread specified when i click the link
    now my brain leaks
  13. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Try this:
  14. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    ok thanx that one works.
    now my brain leaks
