What did this 350 come from?
Discussion in 'The Garage' started by HarryH3, Aug 18, 2005.
  1. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've got a 350 in the garage that I picked up a while back just to mess with. I finally got around to taking it apart and now I'm trying to figure out what it might have come out of! Here's what I've found so far:
    Castings marks say 5.7LG - Block is a 14093638, just your run-of-the-mill 87-95 350.
    The heads are also pretty generic - 14102193, 87 and up.
    It has a factory roller cam.
    The odd thing is that the oil pan has a threaded bung, about 2 inches above the oil drain plug, and there is also baffle inside to help keep oil in the sump. :confused: The pan appears to be a GM factory part. Any ideas what this thing might have come out of????
    Also, is there any way to ID the roller cam? I don't see a part number on it at all. :doah:
  2. dyeager535
    26,982
    191
    What's the suffix code?
  3. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I'd bet a "B" body. Road Master or Caprice or a Custom Cruiser. Corvette also used an oil level sensor. Thats what that bung is for.
  4. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    roller cam not truck . and sump trap and sender = car like above. good to swap to your truck with the roller cam stuff .
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    There's "SGI" under the 5.7LG casting mark.
    Also LO32 to the right of that.
  6. dyeager535
    26,982
    191
    Up front, passenger side of engine, where head meets deck. Stamped in. Should be partial vin + 3 digit code. (maybe other stuff, but something like "CXX")
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Hmm, even on close examination with a flashlight, I can't see any numbers stamped anywhere on the block. :confused:
  8. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    It would be on top of the block just infront of the pass head.
  9. dyeager535
    26,982
    191
    Not sure why they have "4" shown twice, but the suffix code will be located where they show the upper 4. Mortec code locations
    If the block has been decked, those numbers are probably gone. Also, I wouldn't be surprised if some crate motor/replacements didn't come with anything stamped there, although I know there are suffix codes for certain replacements.
    Also, on the next page I believe they show an actual picture of the code location.
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Found it after scraping off some surface rust. :doah: It's on top of the boss that is just above the pass side water pump opening. Last 3 letters are SAF.
    BTW, any ideas on ID'ing the roller cam?
  11. dyeager535
    26,982
    191
    Apparently it's an L05 (185HP TBI 350) out of a '93 Impala or Roadmaster.
    Cam ID: not sure if anyone is keeping tabs on them, from what I've seen they usually have numbers on them somewhere if stock.
    You can bet in those vehicles and that HP rating, it's a torquey cam with no top end.
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Thanks Dorian! I'll examine the cam more closely today and see if I can find any sort of markings on it.
  13. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I finally found the numbers. 155-CPC-BC-11 However, a Google search on that string comes up empty. :(
