what diff cover?
Discussion in 'The Garage' started by K30Blazer, Oct 11, 2005.
  1. K30Blazer
    K30Blazer 1/2 ton status Premium Member
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    Currently I run 3.42 with a ten bolt and a gov lock rear and open front. Will be going to a 12 bolt rear with 35 spline and 4.11's and detroit and a auburn posi up front. What diff covers should I spec out?
  2. Tenpack
    Tenpack Registered Member
    Feb 7, 2005
    16
    Vancouver, B.C.
  3. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    Not meaning to hijack but how did you get a 35 spline 12 bolt? Did you use a spool, or does someone make a locker with 35 splines?
  4. K30Blazer
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    sorry, I think I meant 32. What is the feeling about the Mag - Hytec covers?
    In regards to the 14 bolt. With new wheels etc the cost is too much. For what I do, the 12 bolt is fine.
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Super "boxy" covers can have interference issues with the gas tank (rear) or tie rod/draglinks (front)....
    Something to consider... the CK5 Vendor forum offers some nice choices too.
    The "Jethro Built" covers have the most beautiful welds you'll ever see. :usaflag:
  6. mrk5
    Apr 20, 2004
    12,333
    1,043
    Northern Colorado
    I have the BlueTorch cover on the 12bolt.
    It is a pain to get it to seal. I have it down now. Throw out the bolts and lock washers that come with the cover. Get some allen head cap screws no washers. Put some of the "Right Stuff" gasket maker on the cover, not the diff or you'll never get the gasket stuff where the cover lines up. I cut the heads off some bolts and screwed them into the diff to use to line it up without having to smear the gasket maker everywhere. Then bring ALL the bolts down snug before applying any serious torque. The welds are very close to the bolts, so you need to allow it to shift around so all the heads can properly seat. Then just torque them down once all the bolts are snugged and seated.
    On the front Dana44 I run a Crane High Clearance cover. Very nice piece. No issues getting it to seal. I wish they made one for the 12bolt.
  7. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    don't believe you can have more than 30 spline on a truck 12 bolt (6lug) axle.
    never heard of 32 spline on a truck 12b either....anyway BTF cover all the way. (that would be Blue Torch Fab)
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Crane makes some beefy covers.
    Harley
  9. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    why not go 14s sf? stronger than a 12 and you can still go 6 lug
  10. K30Blazer
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    I didn't know you could do a 6 lug. I am not too concerned about the 14 bolt though as I don't get super aggro with it.
