what do I do? need to get inspection, need driveshaft...but
Discussion in 'The Garage' started by jakeslim, Apr 6, 2003.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Ok big problem... I have a d44 upfront and a 12 bolt in rear. I also have a D60 sitting pretty in my garage until I get my 3/4 rear. I need to get k5 inspected and I need longer driveshafts for current setup(6 inch). I have a 203 with a fixed rear transfer yoke.
    1) can I buy a one ton shaft(s) that will fit the d44 and 12 bolt now, then also work on the d60 and 14 bolt when I get it in?
    2) if so, will i need to change yokes? ujoints? both? need part numbers if you have them.
    3) if not, what would you recommend?
    Thanks for the help
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Yes. Just use a conversion ujoint on the axle in the back. I converted from a 10 bolt front to a d60 and it used the same joint. I'm not totally sure if the D44 and D60 are the same though.
    Napa part # for my conversion u joint was 447. 1350 on one and 1330 on the other. There is another # for a conversion joint but not sure off the top of my head and I'm thinking that might be the one you need for the 12 bolt yoke.
    Thanks for the help
    I would get the shafts and just swap the ujoints on the axle end like I mentioned untill you swap axles. /forums/images/graemlins/thumb.gif
  3. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    thanks Wayne. I am going to order the one tons. Is there an issue with length of the d60 and 14 bolt though? Is it possible for the shafts to be too long when I switch to the bigger axles? Just wondering.
  4. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I doubt there will be that much difference to worry about. I ran 4" lift on the stock shafts with 1 ton axles with no problems.
