What do I got
Discussion in 'The Garage' started by fire dawg, Jul 30, 2005.
  1. fire dawg
    fire dawg Registered Member
    Jan 24, 2005
    28
    new mexico
  2. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    can,t get to the pic
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
  4. fire dawg
    Jan 24, 2005
    28
    new mexico
    fixed the link
    Sorry about the link, fixed it. I know I have a 14bff with 410 gears. I was just wondering what was inside as far as lockers or what not.
  5. fire dawg
    Jan 24, 2005
    28
    new mexico
    anyone have any idea?
  6. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    looks like a...
    I havent looked at mine in a while so I cant say for certain. Let me ask first where it came from? Is this an old CUCV axle or from a stock k30? To me it looks a lot like the original open carrier. Cant really tell though as I cant see if the spider gears have been swapped out with locker parts. If it came from a CUCV then it would be that gov-lock, sorry not to familiar with those things. Well I guess this didnt help at all!!! :confused:
  7. fire dawg
    Jan 24, 2005
    28
    new mexico
    Well, I'm pretty shure the PO said it came out of a K30 in a junk yard. When tires are off the ground, both wheels spin. That means locker right?
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Looking at your picture it looks like the gov loc I have in the garage. So a limited slip not a locker.
  9. fire dawg
    Jan 24, 2005
    28
    new mexico
    gov lock, all right. Thanks for the info
  10. masterbeavis
    masterbeavis Registered Member
    Aug 10, 2004
    20
    El Dorado ca, East of Sacramento
    BZZZZT!! Wrong!! :p CUCV's had detroits, and HUGE 14" drums. :beer:
    Heh, I used to think that GOV-LOK was something that the military invented... :D
  11. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Its a Gov-loc 14bff. There should be 3 "holes" on the edge of the carrier right by the ring gear if its a gov lock, if theres four its either open or has a detroit. But the spacing looks like 3 :crazy:
  12. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    if the wheels spin in the same direction and if you put one on the ground and the tranny in Neutral and you still cant spin the one thats not on the ground its some kind of locker/limited slip. if they spin opposite directions or with one tire spins in the air and other touching the ground its open.
  13. dyeager535
    26,980
    Gov-locks can't be tested that way.
  14. fire dawg
    Jan 24, 2005
    28
    new mexico
    Well, I'm guessing it's a Gov-Lock because the tires rotate in oposite directions.
  15. dyeager535
    26,980
    If you've still got it up in the air, if you give one of the tires a hard jerk in one direction, you can typically get the gov-lock to operate, and you'll feel/hear it lock up on you.
    That is, of course, unless it's already broken lol.
  16. fire dawg
    Jan 24, 2005
    28
    new mexico
    Well, with the tires off the ground, if you spin one tire, the other spins opisite. if you turn the ring gear, they both spin the same direction. There are 3 holes next the ring gear. Does this sound like a gov-lock
  17. sandawgk5
    Oct 28, 2003
    6,881
    If it has three holes in the carrier for cross shafts then it is a gov-loc. I said it was a gov-loc because the carrier is smooth on the passenger side of the case almost like it has been machined. I have one of each in my garage and you def have a gov-loc.
