what do i got
Discussion in 'The Garage' started by noho blazen, Oct 26, 2006.
  1. noho blazen
    noho blazen Registered Member
    Oct 7, 2006
    19
    mass
    just got a new motor today it is a 350 block bored 80 over with a 400 crank and right now i have a tbi 350 in my blazer just woundering how hard it would be to swicht to carb and would i able to use the tbi distibitor,fule pump,coil.tomarrow i get to pick up my tranny t case from the shop th350/205
  2. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,033
    1,347
    Kzoo, Mi
    80 sounds like a lot, you sure about that? If so, that would be like a 392?
  3. noho blazen
    Oct 7, 2006
    19
    mass
    i am defintly sure it is 80 over that what the top of the piston reads
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    392 is correct.
    0.080" over is fairly uncommon. That is farther then I would go on an over bore, but if you are using an older heavy-casting block, you might get away with it.;)
  5. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    i heard you can take them .120 over:confused: :confused:
    is that true?
  6. badmix
    badmix 1/2 ton status
    Nov 7, 2004
    4,205
    60
    West Virginia
    I always thought .060 is the limit on a street motor. I wouldnt touch a .080 motor. but thats jus me. :D
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    its probably .030, the stamps often look very similar.
  8. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I would double check that stamp, 080 is alot. As long as the cam isn't huge, you can run the TBI. Built a 406 in my old truck and ran like a raped ape, and used stock TBI everything.
  9. Disciples Performance
    Disciples Performance 1/2 ton status
    Dec 6, 2005
    404
    Kelowna BC, Canada
    .080 would put you into the raw casting/water jackets of the block my friend UNLESS they resleaved the engine with some crazy sleaves
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    not necessarily into water. i didnt hit water with the one i sleeved until i got to 4.190.
  11. Disciples Performance
    Dec 6, 2005
    404
    Kelowna BC, Canada
    ya didnt that engine heat up like a mother? thats a HECK of alot of bore to go with thats for sure .... even .060 is alot
  12. 76zimmer
    Nov 14, 2005
    23,033
    1,347
    Kzoo, Mi
    If you can measure the bore (even with dial calipers) it would be like 4.030 (30 over=383) if its 4.080 that would be 80 over 392
  13. noho blazen
    Oct 7, 2006
    19
    mass
    i bought the motor to a machine shop and had the bore mesured and it is 80 over they it would be fine and ? on the a older bloch you just take out the plug that goes into the water jacket for the nock senser
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
  15. noho blazen
    Oct 7, 2006
    19
    mass
    on the block near the oil pan there are sqare head bolt things on each side and on my tbi stock motor it look like the knock sensor goes there
  16. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    yeah, that's a block drain on the older engines...
    whats that got to do with anything? :confused: :confused:
  17. noho blazen
    Oct 7, 2006
    19
    mass
    is that where the knock sensor goes
  18. balterbuilt
    balterbuilt 1/2 ton status
    May 10, 2004
    385
    Santa Rosa
    i had an engine i bored .090 over and that motor lasted about 4 years (dropped valve took it out on interstate 5).
  19. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    yeah... it is...
  20. noho blazen
    Oct 7, 2006
    19
    mass
