What do i need for 10 bolt rear rebuild???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by protechk5, Dec 15, 2004.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    Ok ive been searching for ever for a 10 bolt around VA and i cant find one the price i want. But i found this guy who will rebuild mine for almost nothing. My spyder gears blew up and i thought that i was going to just use my 14bolt and throw the 10 bolt away so i just took the driveshalf off and drove it around with no fuild and the metal parts still inside for a while, so i need like everything to rebuild it, so my question is what do i need to buy for the guy to rebuild my rear. thanks
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Probably a master install kit ( all bearings , races , seals , shims etc ) , a locker if you like , or at least new spiders , a new ring and pinion if you ruined the gearset riding around with no juice in it , and some wheel bearings and seals :xmas:
  3. protechk5
    Sep 26, 2004
    2,015
    VA
    i was just thinking, i have a 3/4 front 10 bolt with 4 10 gears, wouldnt i be able to use everything out of that excetp the gears?
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I tihnk it would be cheaper and easier to just go get a 14bff with the 4.10's, stronger and easier:grin:
  5. protechk5
    Sep 26, 2004
    2,015
    VA
    ha i already got a14bolt with 410 but im just doing this to sell my truck, i dont have time to fool around with all of that
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    Everything in the front 10 bolt will be the same as the rear, even the gears. So just swap everything over. :)
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    BK (has bearings races, crush sleeve, nut and seal), IPK , R&P (make it easy on the guy, dont be cheap and get Genuine Gear), Wheel bearings and seals (should come together) and maybe axlesand carreir id its bad too.
