WHAT DO i NEED FOR BODY LIFT
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by madups311, Dec 2, 2001.
  1. madups311
    madups311 Registered Member
    Nov 14, 2001
    72
    VA
    Hello, I hjave a 79 jimmy w/ 4" trail master suspension lift. I have just recieved my 3" body lift. Can any one tell me what I need to do this such as shocks and brake line extensions???
    1979 Jimmy 4" skyjacker, add-a-leaf, 35" M/T's, Body Lift purchased.
    2001 Pathfinder LE Mile Marker Winch
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I don't think the shocks will be affected at all cos all your lifting is the body. I dunno about the brakelines though. I'll tell you what will need and thats PATIENCE. I just replaced the bushings on my blazer 2 weeks ago and I'm still cussing about it! I will never ever ever do that again.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Might need to lengthen some wires, maybe play with steering shaft a little to get it to hook up, 4wd shifter, shifter for trans if you have an automatic, lengthen the pipe for the gas filler......
    Basically, anything that runs between the frame and body may be affected.
    Tim
  4. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    never done it but i understand that the fan shroud will have to be cut some at the bottom because the body is going up but not the engine and the linkage for you shifter if its a auto will have to be lenghtened (sp) hope this helps
    <a target="_blank" href=http://coloradoK5.com/gallery/Pauls89K5>http://coloradoK5.com/gallery/Pauls89K5</a>
  5. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    You have to weld in an extension piece for the shifter linkage (auto trans), the break lines coming out of the master cyl have to be streached downward, you will have to adjust the hose going to the gas tank from the filler neck, you have to melt out the little plastic pins in the steering shaft. The bumpers look goofy after a body lift (my opinion) because the body is now 3in higher so some people make brackets to compensate for this. You may have to adjust the tcase linkage, but I didnt with a 208c. Other than getting the rusty body bolts out and delaing with rotten bushings, that should do it!
  6. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    I did a 3 inch black diamond bodylift from warn. I also took some pictures. One advice is to get some of those knee-pads carpenters use. My knees whas hurting for weeks after I did mine. And my knuckles, and my eyes from getting crud in the trying to get the #@$%£ bolts off!
    Check out the pic's: <a target="_blank" href=http://www.espen88k5.alloffroad.com/photo.html>Takes some time to load these</a>
    <font color=red><a target="_blank" href=http://www.espen88k5.alloffroad.com>www.espen88k5.alloffroad.com</a></font color=red>
  7. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    They were that bad eh? lmao [​IMG]
    -Aaron
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
  8. Espen88k5
    Feb 19, 2000
    981
    Norway
    Every truck is a litle diffrent, all the wires, radiator hoses, brakelines running from the master cyllinder, filler hose was plenty long. But my fuel line running from the filter on the firewall(diesel) was to short. Also the emergency brake cable got to tight while lifting, so I had to release it while I was lifting.
    The rest should be in the instructions you got. Also do a search on bodylift. Somewhere in the arcives are some diagrams on the steering coulumn issues you might incounter as well as other replyes with good tips in them.
    Good luck! And start spraying bodymounts with the best rustloosner spray money can buy. Do that for atleast a week before you go at it.
  9. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Buy some PB Blaster and soak all the bolts real good and think about replacing the body bushings while you're there ......... you won't want to do it later after doing it once !
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
    <font color=purple> BOW CHICKA BOW WOW !
  10. Espen88k5
    Feb 19, 2000
    981
    Norway
    *shrug* I dont even like to think about bodylifts this early in the morning[​IMG] It's 08:46 am here in beutifull ice-cold Norway. Nah! the bodylift is not that bad.[​IMG]
  11. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Espen88K5.......
    HAHAHAHAHAHAHAHAHAHAHAHAAAAAA!!!
    I just found your photos of "Potato Salad Hill".....I think I peed my pants! [​IMG]
    That's really funny.....I think you should come up with a few more, and do an article for CK5...."Ways to have fun when you can't go outside"
    What a comedian.....[​IMG]
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
  12. Espen88k5
    Feb 19, 2000
    981
    Norway
    When my son and I play with his toys, he's 2 years old by the way, he watches me and "copy" what I do. He has a lot of lifted pick-upp trucks and one really big one that's remote controlled. Well the other day we are attending this kid's birthdayparty and after the cake all the kids run around like redhaired stepchilds on speed, exept for my boy who is on the floor slowly climbing a bean-bag chair with a toy pick-upp he's found. Head tilted, stiff upperlip, eyes focused on the roling wheels. Then when he's almost at the top it looked like he hit a rut, rear tire bead blew out, and he rolls "slow motion" to the bottom of the hill.
    He makes me so proud.[​IMG]
  13. madups311
    Nov 14, 2001
    72
    VA
    Notice the gin bottle near potato salad hill
  14. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Yes, I saw that bottle of gin there too.....I think I know the "inspiration" for those photographs now!!! [​IMG]
    -Greg72
  15. Espen88k5
    Feb 19, 2000
    981
    Norway
    <hr></blockquote>
    [​IMG][​IMG][​IMG] Right you are.... actually I was cleaning out the refridgerator and was trowing perspired(sp, out of date?) potetosalad away, when I got the idea for the shots. I had just read about potatosalad hill and turkey leg etc on a web-site somewhere, and influensed by a couple of gin-tonics it seemed like good idea at the time. [​IMG]
