What do I need for hydraulic clutch?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Nov 8, 2000.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    What all do I need for a hydraulic clutch setup? I understand a new bellhousing is needed - what years would I look for that?
    What other parts would I need?
    -- Mike
    SM465
  2. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    Well, it's been awhile here, but I think I used the clutch slave cly and the slave from a late 80's S series truck. Not sure it's been about 10 yrs. I used my old bellhousing and made a braket that bolted to the bellhousing. It worked well. I used pure Chevy parts on the install. GoodLuck, GOPHERKILLER
  3. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    I'm needing this info. too!
  4. Captkaos
    Captkaos 1/2 ton status
    198
    Birmingham, AL
    I have the part numbers...
    I am converting my truck to hydraulic using the factory pieces. I have the part numbers for everything but the bellhousing and the actuator. I am going to use a Lakewood Blowproof for a 84-92 Camaro (PN 15020) and the actuator and fork from the same.
    GM still has most of this just ask for part from a 88-up Blazer. If you want the PN's I have, email me captkaos@wwisp.com
    Chris Lucas
    http://www.captkaoscustoms.com
  5. K2500
    K2500 Registered Member
    Sep 28, 2000
    64
    Alamosa CO
    Re: I have the part numbers...
    You said an 88 and up?? I am currently in the middle of converting to manule w/hyd.. I am using the parts from a 85. Just wondering if I am missing a step or two.
    <font color=red>I finally fixed the leak[​IMG]
  6. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    The rruck I drive at work has one its an 88
  7. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    If your looking for used parts, full size '86 and up had hydraulic clutch. Don't know how early they started, but 86 was definitely hydraulic.
  8. Captkaos
    198
    Birmingham, AL
    That is the years that==>
    That is the years that are still availible for GM. Sorry for the confusion. I believe '84 was the first year for hydraulic clutches.
    Chris Lucas
  9. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    Re: That is the years that==>
    I think it would be easier to use a hydraulic throwout bearing and slave cylinder.I think Summit has these for chevys.Brady
    '73Beautiful Disaster
  10. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    get in touch with advance adapters, they be able to help you out. but as brady said, maybe using a hydraulic throwout bearing will work. i know a friend had one for a camaro, but i dont know how they work in 4 wheel applications....anyone?
    Knife.
    knife.coloradok5.com
