What do I need to do a junkyard 12bolt disc conversion?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nrose07, Mar 21, 2002.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    What do I need to look for to do a disc brake conversion with junkyard parts on my 12bolt? Do the caddy calipers work? Thanks guys!
  2. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Do a search for 12 bolt discs. I have made the list too many times!
    There was just one last week or 2 weeks ago...
    Mike
  3. TULSAK5
    TULSAK5 Registered Member
    Feb 20, 2002
    93
    Broken Arrow, Oklahoma
    I did a search and came up empty handed. Did you find any information. I'm also interested.
  4. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    According to the "search" there hasn't been a post about 12 bolt discs in the last 6 months. I searched Thumpers posts and found a few references back in December and November to backing plates and proportioning valves, but no "List" of components...How 'bout it again Mike???
  5. dyeager535
    26,980
    It's there, and the date of some of the posts was the 12th of March. If you want an e-brake on the caliper though, there still isn't much info.
    make sure you are searching by the right username/spelling/caps or not... 12 bolt disk using "and" or "phrase" for the past year turned up nothing. But it did come up using the correct username.
    Hows this: http://coloradok5.com/forums/showthreaded.php?Cat=&Board=blazer4x4&Number=352145&Search=true&Forum=blazer4x4&Words=thumper&Match=Username&Searchpage=0&Limit=25&Old=3weeks&Main=351353
  6. Michael
    1,576
    Sherman, Texas
  7. Michael
    1,576
    Sherman, Texas
    Thanks Dorian and Mike...that search is kinda wacky...I left off the "to"...silly me..../forums/images/icons/blush.gif
  8. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    If you want good cheap caliper mounts, try this place... <a target="_blank" href=http://www.speedwaymotors.com/>http://www.speedwaymotors.com/</a> Look under Race Products/Brakes/Mounts. They make some really nice weld on mounts for about $15 each. I planned on making a plate that would bolt to the end of the axle housing and then welding the mounts to that plate. That way if I destroy the housing I can just swap everything over to a new one.
