what do i need to know to swap a steering box?
Discussion in 'The Garage' started by boggerless, Oct 21, 2005.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    mine leaks at the rag joint so i took one off a truck in my dads back yard.is there anything i should know?pitman arm location and stuff. thanks :D
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I replaced the seal in mine there , pretty easy if you wanted to go that route .
    Are you running crossover or not ?
    If not the 4wd box pitman arm is easy , it only bolts on one way , so you center the box , and bolt it on .
    Just beware that around late 79 they changed the fittings , to an o-ring style , like a/c hoses .
  3. boggerless
    May 26, 2003
    22,728
    96
    its a two wheel drive box.no cross over YET. :D what up PAUL?are the boxes different?and you said the seal was easy to change ?!?! :D talk to me big daddy.
  4. boggerless
    May 26, 2003
    22,728
    96
    re-reading your post,it is an 80 chevy 1/2 ton 2 wheel drive. :rolleyes: it better work. :mad: :laugh: :laugh: :laugh:
  5. outlawtorn
    outlawtorn 1/2 ton status
    Jul 21, 2004
    365
    Box Elder, SD
    I dont have any personal experience with this.. but from what ive heard its a beoch to convert the new style fittings to the old... and most people just swap the sector shafts if this happens to them.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    No crossover , but using a 2wd box = transfering your sector shaft OR finding a flatter pitman arm for teh 2wd box .
    The seal was super easy . There is an exploded view floating around this forum somewhere , or I can shoot you one tonight :D
  7. boggerless
    May 26, 2003
    22,728
    96
    that would be the more betterest,subject change--if you saw TAYLOR now you wou think you were in another city.way built up.anyway the box looks the same except the short pitman arm.
  8. boggerless
    May 26, 2003
    22,728
    96
    thanks ,bro it all looks the same so i hope its good.i guess thats what happens when it sits.things leak.other than that JR is baaaad asss. :D
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    pauly howdy i need that diagram badly if you could that would be excellent, as my box is leaking at the rag joint too,
    thanks!!
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    no it is actually simple, swap the fitting in the back of the pump with the other, and the hoses, or at least the hi presure one, and the metal part of the low side line
    been through this a million times
    79 was last of the flare fittings
    80 started the new o ring type fittings
    easy swap
