What do I need to stuff 35x14.50x15s in my stock rig?
Discussion in 'The Garage' started by weisel, Sep 4, 2002.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I just got a set of tires for free and want to know what I could do to get them under the truck?
    Money is tight and I would rather not fork it over for a lift kit yet. Would fender trimming and
    a 2" suspention lift fit them meats? Anyone else running these tires, and if so what lift/trimming
    did you have to do?
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    2 inch suspension, then 1 inch body lift from ORD, then get 4 Zero rate adda leafs, that would put you at 4 inches, with some medium fender trimming you can clear those tires easily
  3. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Sawzall. /forums/images/icons/grin.gif
  4. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    That's my first thought....SAWZALL!!!OK,maybe zero rates($30),extended shackles($30),and add-a-leafs($40).That's $100 plus you might need shocks($100).For $295 and shipping($50),you can get an Rough Country 4" lift with shocks.Otherwise use the sawzall!Mike
  5. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    plasma cutter /forums/images/icons/tongue.gif
    NITRO
  6. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    If your going to wheel the truck then either fenders by sawzall or fenders by tires will happen. That is unless you lift it to the sky and put on 6" bump stop extensions.
    315/75 (35 x 12.50) on 16 x 10's, 2-1/2" lift and standard trimming. 14.50's will prob need more of both depending on wheel offset and how much rubbing you can live with. If its never off road, then never mind.
  7. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Yeah, that too. But it takes the FUN out of it...easy to do (for most), nice clean cuts. At least with a sawzall you can really f*ck stuff up. Shocks, brake lines, bumpers, your arm.... /forums/images/icons/crazy.gif
