What do shims do for you?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chvyhs, Dec 25, 2001.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I have a '90 Suburban that I'm putting 6" springs in. I want to know what shiming it will do and why I might need to shim it.
    <a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
  2. lasvegas
    lasvegas 1/2 ton status
    Feb 27, 2001
    122
    Las Vegas, Nevada
    you shim it to adjust the pinion angle. This allows you to rotate the differential to the proper angle for the driveshaft
  3. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    That's it.
    Brian
    83 K-5 4" on 35's
  4. chvyhs
    Feb 12, 2001
    1,469
    I'm sorry, I should have mentioned it's the front end I need to know about.
  5. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    same thing applies but you also lose all your caster when shimming
    of course you could restate the question with more info?
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Basically like was said the shims make the pinion point up more and eases driveline vibrations. The front is a trade off... the more degree the worse drivability you will have with the alignment. Try and go the smallest shim possible. If you drop your tcase you are going to hurt the angle more on your front driveshaft (but it will ease it for the rear). Generally there is a compromise on the front to allow decent drivability, yet allow the vibes to be not very bad in 4wd. Most trucks are converted to part time now and most times your don't need to be going 55 plus in 4wd. If it is that slick out slow down to 55 in 4wd or whatever speed. What i have seemed to find in my research is w/ 6" springs usually need 4 degree springs w/ the tcase dropped, or 2 degree shims with no drop. I curently have about a 8 to 10 degree shim in the rear for my cv shaft w/ no tcase drop and a 2 degree shim up front.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  7. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
    how is the cv joint in the rear working for you? still get vibes?
  8. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    Well if you have vibes from a shackle flip or diveline angle they work great. I would go with one of Jess's one tone CV's. They are worth the money. I did have some vibe problems but one was a bizarre problem w/ the CV joint which has been since and the other has been the batle of the 1/2 ton rear end. [​IMG]
    -Mikey
