What do u think? ARB vs. Eaton E locker
Discussion in 'The Garage' started by BIGRED74K20, May 17, 2006.
  1. BIGRED74K20
    BIGRED74K20 Registered Member
    May 23, 2005
    82
    23
    Northwest
    I have a 74 k20 14 bolt/D60 i already have a spool in the rear but this is usually a DD. But i cant make my mind up what i want to put in the front end so im asking what would you do?:confused:
  2. GM4wheeling
    GM4wheeling 1/2 ton status
    Apr 10, 2006
    337
    Ft. Bragg NC
    sorry to go off topic... but since you have a K20, i want to ask. Whats the easiest way to tell if a truck is a K10 or a K20? Bought a '74 "K10" but it's had body work and the eblems removed. I'm wondering if it may be a K20. How do you tell?? By the way it's got a 3" lift and a body lift...so it's got different front springs...
  3. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    K20 would have 8 lug wheels, but the axles could have been swapped.
    As for the locker, ARB is proven tech, but more to go wrong.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Do a search over at www.colorado4x4.org I seem to recall reading that a few people have busted their E Lockers. :(
  5. mrk5
    Apr 20, 2004
    12,327
    1,031
    Northern Colorado
    A new member that a I met on our last trail run has the E-locker in his D60. He said that he hardly ever locked it in, because it functions like a limited slip unlocked. ivie29 is his screen name here.
  6. DaPlumber
    DaPlumber 1/2 ton status
    Apr 4, 2003
    212
    Holland Oh.
    I like the ARB:D
  7. dyeager535
    26,975
    What axles were they breaking them in though? Not that busted spiders should be an issue, but application may have some to play in that.
    The Ected is looking pretty interesting though, although for a front that might not be the best choice...but in a mainly street driven truck rear axle....
  8. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Sounds like you're confusing the Eaton e-Locker with the Detroit Electrac...???
    The e-Locker is a 100% open diff when unlocked....the Electrac is a limited slip that converts to a full locker at the flip of a switch.
    I'll have to check those threads to see if the broken lockers are Eatons or Detroits....I am planning on installing the Eaton in my D60. :thinking:
  9. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I am running an ARB in my Dana 60 and 42" beadlocked IROKs. I have yet to have any issues with it.
    You can't beat a selectable locker in the front. I run drive flanges so I can't unlock the hubs on the street. With the ARB, you can't tell you are locked in. But flip the switch and your good to go. I had a limited slip in the front before the ARB and I did not like it on the trail or the street. It was worse than a non-selectable locker, because it did not want to slip or unlock unless you had a tire off the ground then it would spin freely...
  10. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
    I'm pretty sure you are also thinking of the detroit electrac. I have heard nothing but good things about the eaton unit and that is what I would get.
  11. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I personally dont have any experience with both, but I would choose the e-locker due to the fact you dont need air, just electricity. Its one less thing to go wrong.
  12. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    No, you don't have air to worry about, but you do have all this other crap to worry about - including relays, switches, wiring, a special diff cover, ect.
    I am not bashing this setup, it was actually my first choice, but I couldn't find one when I was ready for it.
  13. dyeager535
    26,975
    I saw a couple references to the Eaton unit breaking, but it doesn't seem to be that common.
    Quite a bit of info on Electrac problems over on pirate though as I recall.
    More options in the Eaton for axles than the Ected at this point.
  14. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    DPI....
    That pic is for the Detroit Electrac, and NOT the Eaton.....correct?? (The photo properties seem to indicate that anyway)
    My understanding of the Eaton e-Locker is that it doesn't require a special cover....it basically just drops in like a standard locker with the exception of a couple of wires to engage the locking mechanism???
    :thinking:
  15. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    That's correct. Here's Eaton:
  16. barbastard
    barbastard 1/2 ton status
    Dec 7, 2001
    289
    Pleasant Hill, California
    I’ve got an eaton e-locker in my rig and love it. I hardly ever have to engage it and when I do it’s usually just to get me over an immediate obstacle and then it’s back off again. No noisy compressor, no air lines, no special diff. cover…very simple and VERY stout. I’ve HAMMERED on my rig and it just laughs back at me. I’ve got full 1 ton gear, 4.56’s, doubler, 39.5” IROK’s, and no issues with beating the snot out of my rig.
    Long story short…I’m glad I got the eaton and wouldn’t EVER use any other selectable locker.
  17. BIGRED74K20
    May 23, 2005
    82
    23
    Northwest
    well it looks like i will give the eaton a shot then, time will only tell what happens i guess?
