What do ya guys think of 39.5" TSL's and 9" of total lift?
Discussion in 'The Garage' started by MudbogAD, Jul 16, 2002.
  1. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    What do ya guys think of 39.5\" TSL\'s and 9\" of total lift?
    This is the combo my Jimmy will be runnin by mid August. My 6" suspension should arive tomarrow /forums/images/icons/laugh.gif /forums/images/icons/laugh.gif /forums/images/icons/laugh.gif /forums/images/icons/laugh.gif /forums/images/icons/laugh.gif . I've also done some fender trimming.
    Do you guys think 9" of total lift will be enough lift for 39.5" TSL's? Add-a-leaves maybe? Any recommendations are welcomed. Thanks for all the help. /forums/images/icons/smile.gif
  2. bUrLyBlAzEr89
    bUrLyBlAzEr89 Registered Member
    Jul 10, 2002
    47
    Nipomo, Ca
    Re: What do ya guys think of 39.5\" TSL\'s and 9\" of total lift?
    thats alot of rubber and id say that with a 9" inch lift you shouldnt have to do any fender trimming what is it 6 suspension and 3 body or something? if you do some fender trimming get some fender flares for it but you shouldnt have too i have 33s on my stock blazer and with a 2.5 lift you can fit 35's
  3. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    to much suspension lift IMO. Everyone has their own taste, but I think 4-6" + fender trimming is juuuust right for 39.5s.
    J
  4. MudbogAD
    Jun 29, 2001
    672
    Ya, I currently have a 3" bodylift with a 2.5" suspension. I'm replacing the 2.5 with a 6" Superlift Super ride. Would it be a good idea to run add-a-leaves in the rear and extended shackles up front?
  5. MudbogAD
    Jun 29, 2001
    672
    It's gonna be used in mainy mud so I kinda want some height. It'll still only be 6" of suspension though. /forums/images/icons/wink.gif
  6. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    I've got the same setup right now on my mud truck, curios to know what you get as responds! Need to buy tires and don't know how big I can go! I've got 6 suspension and 3 body! with 1 ton axles! so about 9"! No Fender trimming though!!!! /forums/images/icons/cool.gif
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    it should work just fine i am running 38x13x16in tsl swampers with a 2.5in lift and some good fender trimming /forums/images/icons/grin.gif
  8. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I run 39.5" with only 6" of lift with no problems most of the time. Cut the fenders good to do it though. Only hits when really flexing. It mud, it never hits.
  9. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Im running 38 Swampers on mine but I am running a 6 and 3 also. Take a look at my pics to see how itll look. I have some flexed pics too. Youll prob need some trimming if you get too flexed up. Mine is trimmed a bit by the PO. In my pics it is flexed as far as it will go w/out removing the front sway bar.
  10. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    go look at The Generals members rides page (12 i think) he is running a 6+3 with 39.5 and had to do some trimming, look at the second page for some mud shoots
  11. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    mine is built mostly for mud and all i have is 8" of lift with 39 boggers. im adding more body lift now so i will be able to twist up as much as a stiff 8" spring will. 6 and 3 with minor trimming is more than enough for 39s. especially tsls which for a 39 are fairly narrow.
    http://coloradok5.com/gallery/albuq47/aao
    http://coloradok5.com/gallery/albuq47/aas
    pretty much my clearance on the front and rear
    Later
  12. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
  13. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    im running 39.5's and 8 inch lift, and last weekend i rubbed this hell out my Inside fender well so im gonna cut that out like they did on UAV and leave the outer fender on as much as possible and test it on a ramp then cut as neccasary, but you will rub with 9 inch and 39.5's on trails and such but flat mud bogging you wont have a problem,
  14. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I am running 36" TSL Radials and about 7" in the front and 9" in the back. The front rubbed like you would believe before I trimmed my fenders and haven't rubbed since. But, if I went with 39.5" it would definatly rub with current fender trimming. The back has not rubbed at all with the current setup. Not sure if it would rub with the bigger tires or not. I am going to trim the back anway when I install the new tube bumper...
  15. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    i'd say that if that's what you want go for it.
    i'm running a 8" lift and 39 boggers with one tons and you gain about an inch after the conversion. i also have the ord shackles in front, but that adds about 1/4 not to noticeable.
    with this pic you can see the fender trimming for both front and rear. the front hack job was not enough and i had to cut about 2 more inches from the rear of the front fender.
    8" with 39 boggers
    you prolly won't have to cut so much from yours because the tsl is a narrower tire.
  16. CK5
    May 19, 1999
    21,622
    701
    CO
    I'm going to run 39.5 TSL's with 6" rear and 5" front with a little trim here and there of course. /forums/images/icons/smirk.gif
  17. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    you will rip out the inner fenders, I guarantee it
  18. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I run 38.5x11 boggers on a 6=3 and they rubbed until I jumped it hard 1 time now there pushed outa the way and don't rub.
  19. CK5
    May 19, 1999
    21,622
    701
    CO
    Well, I still haven't got my Trailreadys yet, but my spare wheel did come in so I had Discount mount up my spare (39.5) of course I couldn't get home fast enough to slap it on to see how it fit. /forums/images/icons/grin.gif Still have to cut the front fenders, but I will prolly do that after I get the doubler in. But so far Daddy likes! /forums/images/icons/grin.gif /forums/images/icons/grin.gif
  20. BOWTIE
    Dec 28, 2000
    2,018
    /forums/images/icons/cool.gif very nice /forums/images/icons/cool.gif
    what size wheels you going with?
