what do you cut metal with?
Discussion in 'The Garage' started by Brian85gmc, Sep 12, 2002.
  1. Brian85gmc
    Brian85gmc Registered Member
    Sep 4, 2002
    37
    Canton, MI USA
    What do you guys normally cut your metals with when your fabbing bumpers and sliders etc.?
  2. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Welcome,,,,,I am sure you will find CK5.com as the best Blazer/chevy/gmctruck board there is.
    anyways, since I am a Po baztud, I use my 18v DeWalt cordless Saw-zall for just about everything.
    Keep wheeling with the 10 bolt and you will see the problem (not that my Dana 44 is any better /forums/images/icons/blush.gif )
    rob
  3. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Everything from a cut off saw to a plasma cutter.
  4. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    When I started out I used a cutting torch. Then I got a 14" chop saw and started working with a lot of 2" square tubing. Now I have a plazma cutter.
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I generally use my Milwakee Sawz-all or an air-powered die grinder.... A plasma cutter is nice when my friend lets me use his shop...
    Chris
  6. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Chop saw, air recipricating saw, sawzall, plasma cutter (soon), and a bandsaw; whenever I get a new pully for it. I just made these today for BABLAZER73's rear disc brackets with the chop saw. [​IMG]
  7. Grim-Reaper
    7,385
    Atlanta
    For big suff like sheet and plate I use a Black and decker Radial saw with a cut off wheel. It's slow but I can get a good straight cut. Works better than you would think with a good abrasive wheel. I had to cut a slot in my 1/4 plate bumper for my roller fairly last week. I was done in about 30 minutes.
    Anything up to about 5-6 inches I use a chop shaw and a little my Makita reciricating (sawszall type of deal) .
  8. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i use a jigsaw with a metal cutting blade.but i only cut up sheetmetal so i havent got a need for anythink heavier yet.
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Horiz/Vert Band saw, chop saw, vari-speed sawz-all, 3" cut-off, air shear.
  10. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    air nibblers, 3 inch cut off, grinder, and var speed sawzall
    teeth in some instances. at work i use flat sheers.
    grant
  11. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I'm ashamed at you guys. (Taking the easy way out)
    I cut my rusted bolts with a hacksaw, and cut sheemetal with a shears. Nothing beats manual labor.
    (Dang, someone get me a plasma cutter, please - I hate hacksaws.)
  12. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Blue tip wrench for the heavy stuff. Cut off wheel, chop saw, or Sawz All for light stuff.
    John
  13. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    what everys handy, i like my grinder with 6 inch cutoff wheels, just watch your fingers though. seen a blue/white jimmy off cherry hill? you? nice to see some other detroit are peeps on here. /forums/images/icons/blush.gif
  14. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Sawzall, fire, hacksaw, die grinder, and whatever else I can manage to get to cut... I don't do very much metal work as of yet though. I've made some go-karts and some brackets, but nothing big.
  15. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Sawzall, grinder, hacksaw, tin-snips, air chisel, cut-off wheel, and a welder with the power turned up to 190 or 200. That gets rid of rods FAST!
